Activity Forums Adobe After Effects Opening a sequence of tif (PSD Layers) files in photoshop or after effects?
  • Opening a sequence of tif (PSD Layers) files in photoshop or after effects?
    Posted by Manojit Ghose on January 3, 2018 at 1:48 pm
    SUB: Opening a sequence of tif (PSD Layers) files in photoshop or after effects?
    1. rendered a multipass tif (PSD layers) seq.
    2. wanted to import the sequence either in photoshop or in after effects (keeping all my layers( passes)) –
    3. doesn’t seem to work when i import the sequence.
    anyone knows any workaround (i know i can render other formats) or tips to make this work.
    please feel free to ask any question in case i was not very clear in explaining.
    thanks in advance cows ☺
    m.
    MG
    Manojit Ghose replied 8 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 3, 2018 at 5:16 pm
    [manojit ghose] “anyone knows any workaround (i know i can render other formats) or tips to make this work.”
    Instead of rendering the multiple passes to a single, multi-layer Photoshop image sequence, render each pass to its own, separate image sequence. You can then import each pass as a separate image sequence and composite them together.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Manojit Ghose
    January 3, 2018 at 8:14 pm
    hi walter
    thanks for your reply…i knew that way infact that was my backup!… I was just curious if there is a way to make the multilayer tif (PSD layers) work in a timeline, i like the ease of handling vis-a-vis exers.
    thanks
    m.
    MG
