Activity Forums Apple Final Cut Pro Legacy Opening a newer sequence in an older version of FCP?
  • Opening a newer sequence in an older version of FCP?
    Posted by Sat1979 on November 29, 2006 at 2:25 pm
    Is there any way to open a sequence that was created in final cut pro 5.1 on a machine running final cut pro 5.0.4?
    Cheers,
    Tim
    Debe replied 19 years, 9 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    November 29, 2006 at 2:35 pm
    Use an XML file from the 5.1. system. That will open in the older system.
    With the low cost of the crossgrade, I’d suggest it’s time to upgrade the older system. Not ever going to be less expensive…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Sat1979
    November 29, 2006 at 3:36 pm
    Hi Jerry,
    Your advice worked perfectly! I’ll be upgrading shortly in the new year!
    Tim
  • Debe
    November 29, 2006 at 4:04 pm
    You might want to push up your timetable if you haven’t already purchased.
    The deal on the upgrade/crossgrade expires on December 20th of this year. You might be very unhappy after that date if you wait to purchase.
    Upgrade any time, just get it now!
    https://www.apple.com/universal/crossgrade/
    debe
