Activity Forums Adobe After Effects OpenGL render error?!?!!? Help
  • OpenGL render error?!?!!? Help
    Posted by Kevin Reiner on December 28, 2005 at 4:53 pm
    Working in 3D with layers and a light. Not too complex of a comp, but I keep getting the error
    “After Effects error: OpenGL: Failed to create render context. (5044 – 0)”
    I’m using the Advanced 3D renderer.
    Can anyone translate what this means and how I can fix it?
    Thanks in advance!
    Reins
    Kevin Reiner replied 20 years, 8 months ago 5,722 Members · 1 Reply
  • Kevin Reiner
    December 28, 2005 at 8:20 pm
    Just to get the project done, I removed the OpenGL plugin from the plugin folder and was able to work again. Should I try to place it back into the plugin folder before doing my final render, or will it be okay to render without OGL turned on? What I want to really figure out is what is “wrong with it in the first place?”.
