Activity Forums Apple Motion OpenEXR layers
  • OpenEXR layers
    Posted by Brad Bussé on August 20, 2007 at 5:45 pm
    I’m working with some OpenEXR CG renders that have extra layers rendered into them – lighting passes and z-depth. How do I access these in Motion? In the channels pulldown I can see RGBA, but nothing else.
    Eskatonia replied 19 years, 1 month ago 2 Members · 1 Reply
  • Eskatonia
    August 21, 2007 at 11:24 am
    I would suggest that if you are doing the sort of compositing where you are getting open exr renders (presumably in float) that you might want to be using Shake instead of Motion.
    shake can read all channels in an OpenEXR.
    I don’t believe that capability exists in motion (I’d like to hear it if I’m wrong)
    Roger
    CoreMelt
