Activity Forums Zaxwerks Open vs Closed Path
  • Open vs Closed Path
    Posted by Hamboy on July 21, 2006 at 6:12 pm
    I am trying to create an open path in Illustrator (CS2) to export to Invigorator in AE. I save an open path as Illustrator 8, open it in Invigorator, and the the start and end of the path are connected by a straight line. I am trying for a filstrip effect like Serge had for a tutorial, but I can’t create an open path. How is this done?
    Serge Hamad replied 20 years, 1 month ago 2 Members · 1 Reply
  • Serge Hamad
    July 21, 2006 at 9:39 pm
    Hi Hamboy,
    – Create an open path using the Pen Tool.
    – Select your path & got to Object>Path>Outline Stroke. This will close your path.
    – Make sure, now that your path is diagonal so the mapping starts at one end of your object (The lower left)
    – In Invigorator switch the front & Back faces off & increase the Depth value.
    – Using the layer mapping technique, create a transparency map that is half-white/ half-black or alpha so you can eliminate the backside of your filmstrip.
    Salut.
    Serge
