Activity › Forums › Adobe After Effects › open v9 win on v8 mac?
Posted by Emmet Reddy on January 27, 2010 at 11:25 amThis is probably a silly question but, is it possible to somehow open an adobe after fx version 9 windows project so it will open on a mac using adobe after effects 8?
Thanks Emmet?Emmet Reddy replied 15 years, 10 months ago 3 Members · 4 Replies -
David Johnson
January 27, 2010 at 12:53 pmNo, but if you search this forum you’ll find some discussions of how various people have manually converted their projects from a newer AE version to an older one. All approaches I’ve heard of are relatively time-consuming so, personally, I consider it a last resort … especially with large complex projects.
Cross-platform is a separate issue … the main things you’ll have to deal with there are font and third-party plugin differences.
Todd Kopriva
January 27, 2010 at 4:37 pmAs David says, the cross-platform aspect is pretty easy. There are a few things to keep in mind: “Cross-platform considerations”
The ability to open a project in an older version is a different issue.
If you have both versions of After Effects on the same computer, you can use a somewhat laborious method to get most information from an After Effects CS4 project back to an After Effects CS3 project. See the tip at the bottom of this page.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
