Activity Forums DaVinci Resolve Open multiple projects worked until today
  • Open multiple projects worked until today
    Posted by Duke Sweden on September 21, 2017 at 11:26 pm
    Yesterday I clicked on 3 different projects with “Dynamic Project Switching” checked and it worked fine. Today when I do it, it opens the “Untitled Project” only, which I didn’t even click on. I know this is something that probably doesn’t happen to everybody so I don’t expect a solution. Just putting it out there just in case.
    When I click on the other projects they get outlined but there’s no checkmark like there is in the Untitled Projects thumbnail. See attached
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
    Tero Ahlfors replied 8 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Glenn Sakatch
    September 22, 2017 at 12:32 am
    Are you saying you can’t double click a second project and get it to open, or you can’t open all 3 with 1 click of the button?
    Glenn
  • Duke Sweden
    September 22, 2017 at 2:19 am
    With Dynamic Project Switching turned on you should be able to shift/click on 2 or more projects, then click “Open” and one will open with the other project available to be switched to. What I’m doing, and which worked before, is Shift/click on two different projects, but the only project that opens is the default “Untitled Project” (which I had changed to “Future Project” as you can see in the image). I can click on the untitled default project all day and it won’t turn off the check mark.
    If I only select one project, it will open, but if I select two projects, then neither opens, just the default “untitled project”.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    September 22, 2017 at 7:45 am
    The checkmark is showing the active project which defaults to the untitled project at program start. You only need to turn the dynamic project switching on in one project and it will activate it globally. Then when you open the project panel the current active project has the orange checkmark and other projects you’ve opened (ie. projects that are open in the background) have a white checkmark and outline.
    Read/search the manual, please.
  • Duke Sweden
    September 22, 2017 at 11:20 am
    Never mind.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Glenn Sakatch
    September 23, 2017 at 3:13 pm
    Duke…keep it simple. Don’t try to open two at once. Open first project, then use your home icon bottom right corner and double click on a second project. Should work.
    Glenn
  • Duke Sweden
    September 24, 2017 at 11:25 am
    Thanks, Glen! And, just for the record, Tero, I didn’t realize that Resolve’s manual comes in a searchable .pdf.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    September 24, 2017 at 5:46 pm
    That’s pretty much the point of pdf manuals.
