Activity Forums VEGAS Pro Open iPhone videos in Vegas
  • Open iPhone videos in Vegas
    Posted by Jono Grant on April 27, 2020 at 11:31 pm
    Hi there, I keep the setting “keep originals” on in my iPhone settings as it’s the only way I can seem to copy my iPhone videos to my computer.
    Currently, I have to re-encode everything using Handbrake to open it in Vegas.
    Is there a codec of some kind that will allow me to open iPhone videos directly in Vegas?
    They open in win media player and VLC etc.
    I used to be able to.. I think.
    Any help appreciated! Thanks
    Jono
    Wayne Waag replied 6 years, 4 months ago 4 Members · 11 Replies
  • 11 Replies
  • Graham Bernard
    April 28, 2020 at 12:32 am
    [Jono Grant] “Any help appreciated!”
    Hi Jono! What version of VegasPro are you using?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Jono Grant
    April 28, 2020 at 2:43 am
    Pro 14
  • Graham Bernard
    April 28, 2020 at 3:09 am
    Do you have QuickTime installed? And if so is it the latest?
    * Grazie
  • Jono Grant
    April 28, 2020 at 3:19 am
    Yes. It’s version 7.7.9
    I remember I had to buy a codec from the windows store to get them playing in windows media player.
    That didn’t help Vegas play them though…
    J
  • Wayne Waag
    April 29, 2020 at 3:42 am
    What type of iPhone footage are you trying to import? avc or hevc? What’s the frame size and frame rate?
    wwaag
  • Jono Grant
    April 29, 2020 at 5:02 am
    This is how it comes off my phone:
    General
    Complete name : C:\Users\Jono\Desktop\IMG_6195.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 0000.00 (qt )
    File size : 369 MiB
    Duration : 4 min 25 s
    Overall bit rate mode : Variable
    Overall bit rate : 11.7 Mb/s
    Encoded date : UTC 2020-04-21 03:00:35
    Tagged date : UTC 2020-04-21 03:05:01
    Writing library : Apple QuickTime
    com.apple.quicktime.make : Apple
    com.apple.quicktime.model : iPhone 8 Plus
    com.apple.quicktime.software : 13.3.1
    com.apple.quicktime.creationdate : 2020-04-20T23:00:35-0400
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main@L4.1@Main
    Codec ID : hvc1
    Codec ID/Info : High Efficiency Video Coding
    Bit rate : 11.5 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 60.000 FPS
    Minimum frame rate : 54.545 FPS
    Maximum frame rate : 66.667 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.093
    Stream size : 364 MiB (99%)
    Title : Core Media Video
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : hvcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Source duration : 4 min 25 s
    Bit rate mode : Variable
    Bit rate : 101 kb/s
    Channel(s) : 1 channel
    Channel layout : C
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 3.18 MiB (1%)
    Source stream size : 3.18 MiB (1%)
    Title : Core Media Audio
    Other #1
    Type : meta
    Other #2
    Type : meta
    Bit rate mode : Constant
  • Wayne Waag
    April 29, 2020 at 5:46 am
    The problem is V14. You can easily import this type of footage into later versions. I have some sample iPhone11 footage that is the same except UHD (3840×2160 at 60 fps) and it imports into V15-V17, so I assume that FHD (1920 x 1080) could also be imported. If you want to stay with V14, you should shoot using AVC rather than HEVC–in fact, use of AVC rather than HEVC is always recommended where possible. For $150, it’s well worth upgrading to V17. Moreover, you don’t need QuickTime installed for such footage even though it’s in an MOV container.
    wwaag
  • Jono Grant
    April 29, 2020 at 4:11 pm
    Hmmmm. Vegas used to play my iPhone videos, and I never had to deal with any of that stuff.
    J
  • Wayne Waag
    April 29, 2020 at 4:37 pm
    If you upload some sample footage that can be downloaded, I will take a look just to confirm.
    wwaag
  • Dimitrios Papadimitriou
    May 2, 2020 at 2:45 pm
    I am using VP16 and also have trouble with iphone footage. If I import maybe 20-30 clips it will work but at a certain clip threshold it will not and just crashed in the import process or upon reopening. I always have to convert them and often I even have trouble with the converted files and have to create video proxies just to be able to edit them without lag and thats for only full hd, normally I only do that for 4k. I usually use ANYVIDEOCONVERTER, for some reason sometimes that wont work either and the only way I could create a usable MP4 was to put them in camtasia and render as one big file then chop it up in vegas. Is handbrake better for making these usable?
