Activity › Forums › Adobe After Effects › open GL previews and renders
  • open GL previews and renders
    Posted by Anita Sancha on August 22, 2009 at 8:20 am
    Hi
    Just to clarify something please.
    In preferences Open Gl is set as a check box for previews.
    Does it only work for previews? Does it actually DO anything when final rendering, e.g. lights with shadows adjustment layers etc, over and above the normal final render if Open GL is unchecked. I cant see the difference on final render.
    Thanks.
    Thanks for all your help
    Anita Sancha.
    http://www.anitasancha.co.uk
    Todd Kopriva replied 17 years, 1 month ago 2 Members · 1 Reply
  • Todd Kopriva
    August 22, 2009 at 4:35 pm
    from “Render with OpenGL”:
    “To enable OpenGL for rendering final output, click the underlined text next to Render Settings in the Render Queue panel, and select Use OpenGL Renderer.”
    But I don’t recommend using OpenGL for final renders. OpenGL is good to speed up certain kinds of rendering for previews and interactions, or for creating proxies, but I wouldn’t use it for final output.
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
