Activity › Forums › Apple Final Cut Pro Legacy › open format timeline
Posted by Joel K. on February 2, 2009 at 2:39 pmSo I will be working on this project that will include various types of codecs. I know FCP 6 has this open format timeline feature so that this is possible to do in one timeline. My project will be in NTSC – Apple ProRes HQ. I will also have footage in HD Apple ProRes HQ (1920×1080) and HDV among others that I don’t know yet. I will also have video in 29.97 and 23.98. As of now the only footage I have in my possession is the SD ProRes and the HD ProRes (both 29.97). The HD ProRes looks great when it’s in a HD sequence, but when I put it into an SD sequence and FCP scales it down, it doesn’t look good at all. The quality is significantly decreased. What’s the deal?
Chris Cummings replied 17 years, 6 months ago 11 Members · 24 Replies -
Aaron Neitz
February 2, 2009 at 3:57 pmTry rendering those clips first. It’s doing an RT downconvert which is going to look dodgy (but it’s in real time!)
Rafael Amador
February 2, 2009 at 4:01 pmHi Joel,
FC can work well with different sizes and codecs in the same sequence. Footage with different time base need to be converted before.
The best solution would be to capture all your HD in Proress SD.
[Joel Kotlowitz] “The HD ProRes looks great when it’s in a HD sequence, but when I put it into an SD sequence and FCP scales it down, it doesn’t look good at all. The quality is significantly decreased. What’s the deal? “
Had you tried rendering with “High Precision” and “Render Motion Effects: BEST?
rafael -
Joel K.
February 2, 2009 at 4:41 pmThe original source files didn’t come from tape, it came from a type of memory card (revPro) so I couldn’t really choose to bring it in as SD…. Are you saying I would need to individually re-export all my footage as ProResHQ SD? Isn’t the point of having this open timeline feature to be able to mix and match footage, codecs, HD/SD, etc without having to conform all the footage?
Joel K.
February 2, 2009 at 4:44 pm“Try rendering those clips first. It’s doing an RT downconvert which is going to look dodgy (but it’s in real time!)”
how would I render it? It doesn’t have a red render bar on top. When I hit apple R, it doesnt do anything.
Joel K.
February 2, 2009 at 4:49 pmoh scratch that. I see I had the timeline in Playback video quality Dynamic… if I change it to High, then I can render… I guess this should be the last step in my process.
David Jahns
February 2, 2009 at 5:55 pmSad to say, but OPEN TIMELINE is simply marketing hype. FCP does a terrible job of downconverting footage – at least if your are working in NTSC interlaced. If you can work in NTSC 23.98 progressive, you might have better results, but it also depends on what footage you’re starting with, of course.
I did a fairly thorough research job on this when FCP 6 came out, then I posted my results here on the COW, and no one really had a solution, other than “use a KONA card to downconvert your footage”.
Check out this link:
https://www.jointeditorial.com/dave_tech/FCP_HD-SCALING-FINAL.htm
Nicholas Bierzonski
February 2, 2009 at 8:56 pmWow! Great post! Just goes to show you how FCP still has a way to go.
-Nicholas Bierzonski
Senior Editor/DVD Author/Java Boy
http://www.finalfocusvideo.com
David Roth weiss
February 2, 2009 at 9:28 pmSo David,
After re-reading your article several times (and memorizing every word) I want to know what your solution is down-converting interlaced HD material?
THNX,
DavidDavid Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
John Pale
February 2, 2009 at 9:44 pm[Nicholas Bierzonski] “Wow! Great post! Just goes to show you how FCP still has a way to go.
“So does every other NLE. Nobody can do that cleanly without hardware (Kona, Nitris, etc.)
David Jahns
February 2, 2009 at 9:44 pmHmmm, I’ve actually never dealt with 1080i source material.
Everything I’ve ever worked with has started with progressive frames, 1080psf24 or 720p60 or 24. The key there was using a progressive timeline to do the scaling, but if you’re staring with 1080i, that won’t work. I honestly don’t know.. except “Use a KONA card!”
