Activity Forums Avid Media Composer Open-Caption DVD??
  • Open-Caption DVD??
    Posted by Andy Devries on June 29, 2009 at 3:57 pm
    Hi folks…
    I’m trying to determine the best method for creating an “open-caption” DVD from an existing Closed-Captioned DVD. Open-Caption, if you’re unfamiliar (as I was), is video with the captions burned-in, as opposed to CC where they can be disabled.
    My best bet is to crash digitize the DVD into Avid MC 3.5 with CC turned on, then lay this back to a new DVD. While I have a DVD player connected to my Avid via a Blackmagic converter, I’m (seemingly) unable to turn on Closed-Captioning directly from the player to the Avid.
    Original CC’ed DVD was created in DVDSP4, would be great if there was an option in DVDSP/Encore to force CC on…then I wouldn’t have to lose a generation.
    Otherwise, Any ideas how to crash record of a DVD into Avid with CC enabled? Thanks.
    Patrick Harris replied 17 years, 1 month ago 2 Members · 2 Replies
  • Andy Devries
    June 29, 2009 at 4:13 pm
    I do have a laptop with a D-sub connection…maybe I can get that to play it out through a monitor, or even directly into Avid? I dunno…I’m reaching.
  • Patrick Harris
    July 6, 2009 at 4:55 pm
    You’ll need to pass the output of the DVD player thru an external caption decoder, then into your Avid. You can get a cheap decoder or an expensive one – your choice. Evertz, Link, EEG all have decoders in various flavors. I’d be happy to walk you thru the setup.
    Patrick
