Activity › Forums › Adobe After Effects › Open a Circular Path?
  • Mike Clasby
    March 16, 2006 at 5:16 pm
    Try Text > Path Text
    Very changable.
  • Serge Hamad
    March 16, 2006 at 7:23 pm
    Hi Dave,
    [Dave LaRonde] “Getting the path circular will be tricky”
    You could easily do it if you draw a circle using the elliptical mask tool, add a vertex using the Add Vertex tool as near as possible to another existing vertex then select both vertex, right click and uncheck “Closed”.
    Salut.
    Serge
  • Axel Rogge
    March 16, 2006 at 7:38 pm
    [serge] “right click and uncheck “Closed”.”
    Huh? AE 7.0 does not give me that check box after a right click.
    Axel
  • Steve Roberts
    March 16, 2006 at 7:40 pm
    Did you try selecting the segment of the path between two vertices? If right-clicking won’t do it, go to the layer>mask menu after selecting.
  • Nicholas Toth
    March 16, 2006 at 8:19 pm
    might take a little while because you have to do it PER LETTER but if you lay the text out using 3d assistants lite….with the cylinder….and spin it with a null… it’ll be closer than setting the text to a path.
  • Axel Rogge
    March 16, 2006 at 8:20 pm
    [Steve Roberts] “layer>mask menu after selecting”
    Hey, that worked – thank you!
    Meanwhile I played with path text. This works as well – I didn
  • Axel Rogge
    March 17, 2006 at 7:58 am
    Thanks, Nicholas!
    But I did it as a combination of serge and Dave
