Activity Forums Adobe After Effects Expressions Opacity semi-random issue
  • Opacity semi-random issue
    Posted by Trevor Navarre on January 15, 2018 at 8:59 pm
    I have a displacement map I would like to flicker on and off randomly, however I would like it to be off more that on and only be on a few times rather than a majority.
    Here’s what I came up with :
    random(0,100);
    if (thisComp.layer(“displace”).transform.opacity < 90) 0 else 100;
    It doesnt seem to randomize once I put all of this in…. any help would be appreciated. Also if there is a way that when it does switch “on” it stays on for maybe 10 frames I’d appreciate a hint on that! Thanks in advance for any help!
    random(0,100);
    if (thisComp.layer("displace").transform.opacity &lt; 90) 0 else 100;
    Kevin Camp replied 8 years, 8 months ago 2 Members · 4 Replies
  • Kevin Camp
    January 15, 2018 at 9:13 pm
    you’re close… you just need to assign the random value to a variable and compare that variable to 90 to set the opacity….
    r = random( 0, 100 ) ;
    if ( r < 90 ) 0 else 100 ;
    note, if the less than sign gets replaced with < manually replace it with the symbol.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Trevor Navarre
    January 15, 2018 at 9:20 pm
    Thanks! Seems to be working!
  • Trevor Navarre
    January 15, 2018 at 10:49 pm
    This is kind of primative but below is what I’m trying to do but just unable to articulate. Any clue?
    if ( r &lt; 90 ) 0 else 100 ;
    if (r = 100) (r = 100 for 8 frames)
  • Kevin Camp
    January 16, 2018 at 6:32 pm
    you could try using posterizeTime() to have a new random value generated every 8 frames (instead of every frame):
    hold = 8 ; // value in frames
    fps = 1 / thisComp.frameDuration / hold ;
    posterizeTime( fps ) ;
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
