Activity › Forums › Adobe After Effects › Opacity of a comp that uses continuous rasterised layers
  • Opacity of a comp that uses continuous rasterised layers
    Posted by Deniz Nasif on April 24, 2014 at 8:13 am
    Hello,
    I have a comp that has 2 illustrator ai layers that are set to ‘continuous rasterize’. I then also set the actual comp in my main comp to the same setting and scale it up to the size I want, and all looks fine. However, when I adjust the opacity of this comp, rather than adjust the opacity of the comp as a whole, each layer of my comp seems to have the opacity adjusted separately and I can see through each layer of my comp. i.e.; I can see the bottom layer through my top layer.
    Why is it doing this and is there a way around it?
    Deniz Nasif replied 12 years, 5 months ago 2 Members · 2 Replies
  • Michael Szalapski
    April 24, 2014 at 4:31 pm
    Scale up the elements in the precomp far enough that you won’t need to scale them up in the main comp. Then, in the main comp don’t set the precomp to collapse transformations.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Deniz Nasif
    April 25, 2014 at 8:40 am
    Thanks for getting back to me Michael. I kinda figured that may be the case. Thanks for your help.
