Forums Adobe After Effects Expressions Opacity jumps to a higher starting point than defined in the linear() expression
  • Opacity jumps to a higher starting point than defined in the linear() expression
  • Hauke Sterner
    March 6, 2023 at 4:20 pm
    Hello all!
    I’m fairly new to expressions and I have a problem with the following:
    L is a static circle that just fades in.
    M is the same circle, but it moves across the composition (only x-position).
    L is supposed to fade in once M hits the x-position of L.
    This is my expression:
    L = thisComp.layer(“Punkt”);
    M = thisComp.layer(“Punkt_Maske”);
    if (M.transform.position[0] >= L.transform.position[0]) {
    L.transform.opacity = linear(time, 0, 33);
    } else {
    0;
    This expression kind of works, but the opacity of L does not start at 0 like stated in linear(), but jumps to a higher percentage and continues to 33%.
    Can somebody tell me what I’m doing wrong?
    Thanks! 🙂
  • Dan Ebberts
    March 6, 2023 at 4:54 pm
    Your expression needs to calculate how long ago the trigger event happened. Also, you didn’t mention how long the fade in should take, so I just set it to .5 seconds:
    L = thisComp.layer("Punkt");
    M = thisComp.layer("Punkt_Maske");
    fadeDur = .5;
    t = time - thisComp.frameDuration;
    while (M.transform.position.valueAtTime(t)[0] >= L.transform.position[0]){
    t -= thisComp.frameDuration;
    linear(time-t,0,fadeDur,0,33);
    } else {
    0;
  • Hauke Sterner
    March 7, 2023 at 6:59 am
    Hi Dan,
    thank you very much! It works like a charm! 🙂
Viewing 1 - 3 of 3 posts
Log in to reply.
