Activity Forums Adobe After Effects Expressions Opacity change with multiple layer markers
  • Opacity change with multiple layer markers
    Posted by Naoko Hara on January 30, 2019 at 9:48 pm
    I want to trigger multiple (two in this case) opacity changes via layer markers on a single layer.
    I used below to trigger one opacity change.
    if (marker.numKeys > 0 && time >= marker.key(1).time){
    thisComp.layer(“N_Op_text”).transform.opacity.valueAtTime(time-(marker.key(1).time));
    else{value}
    The expression looking at a null layer with opacity change. “N_Op_text” makes the opacity go from 100 to 50%.
    If I want to manipulate this exp so it would be able to trigger another opacity animation (eg. it will look at a different null layer named “N_Op_out” that makes the layer go from whatever current value is to zero), how would I do that?
    THANKS
    thisComp.layer("N_Op_text").transform.opacity.valueAtTime(time-(marker.key(1).time));
    else{value}
    Kalleheikki Kannisto replied 7 years, 7 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    February 3, 2019 at 12:58 pm
    You could do it like this, if you need it to go to 0. If you need it to match the opacity of another layer, replace the “0” by pick-whipping the opacity of that other layer.
    if (marker.numKeys > 1 ){
    if (time >= marker.key(1).time){
    if (marker.numKeys == 2 && time >= marker.key(2).time){0};
    }else{value}
    }else{value}
    (Will only work properly if you have two markers on the layer.)
    Senior Graphic Designer
