Activity Forums DaVinci Resolve Opacity
  • Opacity
    Posted by Michael Stirling on November 12, 2011 at 12:49 pm
    Hi
    I have a project that has come from a FCP7 xml which contains clip opacity info (ie the editor was using the clip overlay keyframes).
    This seems too have come through into my conform (some clips are semi transparent) but I can’t control or alter or see how much or on which clip this is happening?
    How is Da Vinci interpreting this info and how can a get control of it as some of it is wrong. (ie some are left on screen alone but 50% transparent
    The offline was a SD DV pal and I’m grading DPX sequences
    Any ideas?
    Mike
    Ola Haldor voll replied 14 years, 10 months ago 2 Members · 1 Reply
  • Ola Haldor voll
    November 12, 2011 at 12:59 pm
    Only way to fix this as I see it; import XML to FCP, fix the problem and export new XML.
    At least, that’s the way to do it if you’re more comfortable with a gui.
    If you don’t mind, I think you could edit the XML in a TextEdit or something similar.
