Activity Forums Adobe After Effects Expressions On/Off expression link to a checkBox
  • On/Off expression link to a checkBox
    Posted by Pierre Josserand on June 6, 2019 at 8:56 am
    Hello everyone,
    i just did a subtitle template with a resized text box in the background, and an opacity animation on the text at each keyframe ( Thanks to Dan Ebberts expression i found here). my only tiny problem is that i needed the text to fade on the key frame so i need to stop the expression when i’m animating, and check it back at the end, and i was wondering “can i checkbox the button to on/off the expression” ( i know it’s only a few click more to do it but aren’t we all lazy and optimized motion designer)
    i’ll join the opacity expression i used
    so if anyone got a solution i’ll be glad to hear your advice.
    Thanks everyone
    fadeTime = .3;
    txt = text.sourceText;
    if (txt.numKeys > 0){
    t = txt.nearestKey(time).time;
    if (time < t)
    ease(time,t-fadeTime,t,100,0)
    else
    ease(time,t,t+fadeTime,0,100);
    }else
    value
    Pierre Josserand replied 7 years, 2 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    June 8, 2019 at 8:38 am
    Like this should work:
    fadeTime = .3;
    effectOn = effect("Checkbox Control")("Checkbox");
    if (effectOn==true){
    if (time < t)
    else
    }else
    value}else
    value
    Senior Graphic Designer
  • Pierre Josserand
    June 8, 2019 at 4:51 pm
    Thanks a lot I’ll try it this week end
