Activity Forums Adobe After Effects Only using 4 gig??
  • Only using 4 gig??
    Posted by Stephan Dube on February 7, 2009 at 5:02 pm
    Hey guys
    I have a quick question Im using Vista 64 with AE CS4 and when I launch AE I notice the splash screen it says USING 4 GIGS. But I have 8 Gigs on my system, is there something Im missing or is that CS4 doesn’t support more then 4 gigs??
    cheers
    stephan
    Stephan Dube replied 17 years, 7 months ago 2 Members · 2 Replies
  • Sébastien Périer
    February 9, 2009 at 2:11 am
    Well, AE CS4 is a 32bit app, so it can use at most 4GIG per process (and 1 process per cpu/core).
    If you want your 8Gigs used by After, go to “Preferences > Memory management” and turn on multiprocessing.
    AE will let you configure on much ram you want tu use on how much core/cpu you want.
    But remember, as it’s a 32Bit app, it will only be able to use up to 4gig of not contiguous memory, so you’ll still have to be carefull with the “buffer memory error” when dealing with very large footage (large == high resolution)
  • Stephan Dube
    February 9, 2009 at 4:09 am
    merci
    I appreciate it man!
    cheers
    stephan
