Activity Forums Adobe After Effects Only Renders One Frame at a time–Can’t Render out
  • Only Renders One Frame at a time–Can’t Render out
    Posted by Ken Silverman on August 10, 2008 at 4:05 pm
    Hi All
    Im in the middle of a typical “can’t render project, deadline is only a few hours away crisis.” I am hoping someone out there might be able to offer some help.
    I have a medium complex animation-not too much stuff, except it does use a reasonable amount of particular and it is in 3d.
    About halfway, it becomes unwilling to render more than one frame at a time. If I hit the space bar, AE renders one frame then stops. If I try to RAM preview the selected area it says there needs to be more than one frame in order to RAM preview. It fails every time I try ot render it out of the project.
    Anyone have any experience with this????
    Thanks so much for any help.
    Robert Craghead replied 18 years, 1 month ago 2 Members · 1 Reply
  • Robert Craghead
    August 10, 2008 at 7:38 pm
    Have you tried to render out the sequence as a tiff sequence. This way you won’t have to start over every time in the render. With plug-ins the cpu might be running out of memory, and quit at a certain point. If you render out in a sequence you can pinpoint the trouble spot and match frame it together later in another sequence, and a lot easier of a render
