Activity Forums Adobe Premiere Pro Only audio, no video in program window
  • Only audio, no video in program window
    Posted by Mahmoud Farah on October 28, 2008 at 8:09 am
    I am editing on premiere. 6 The problem is I have only audio and no video on the program window . you can play the clip on the source monitor and see the video and audio playing but once you put the clip on the timeline then you just have
    Tony Vivian replied 17 years, 10 months ago 3 Members · 2 Replies
  • Mike Velte
    October 28, 2008 at 11:03 am
    It is likely the video codec is incompatible with Premiere. The Source window works the same as media player, but not the Program window. Use GSpot to determine the codec.
  • Tony Vivian
    October 30, 2008 at 8:55 pm
    If the previous post didn’t solve your problem – are you running dual monitors? I’ve run in to this problem every now and then where you set your timeline program monitor on your secondary monitor and the graphics card isn’t set up to display that video properly so you only get audio. Returning the timeline program monitor to the primary monitor will fix it.
