Activity Forums VEGAS Pro only 2 min records out of a 22 minute video
  • only 2 min records out of a 22 minute video
    Posted by Edgar Gillham on May 23, 2015 at 12:40 am
    I created a 22 minute video and ran a preliminary burn on CD-RW, worked fine. I then added text to the video and tried to run another copy, only 2 minutes records. que pasa?
    enjoy yourself, it’s later than you think.
    Edgar Gillham replied 11 years, 3 months ago 2 Members · 3 Replies
  • Bob Peterson
    May 23, 2015 at 1:33 am
    Did you have a loop region set up, and opted to render only the loop region? That is what it sounds like. In the “render as” window, unclick the “render loop region only” option.
  • Edgar Gillham
    May 24, 2015 at 12:01 am
    Thank you for the reply. I made no changes after burning the preliminary DVD-RW except to add text, however your suggestion sounds like a good place to start.
  • Edgar Gillham
    May 25, 2015 at 4:15 am
    I checked the above suggestion but that was not the answer, render loop only box was not checked. Any other suggestions?
