Activity › Forums › Compression Techniques › “One or more targets are incomplete. Each target assigned to a job must have a setting and a destination.” (Compressor 4)
  • “One or more targets are incomplete. Each target assigned to a job must have a setting and a destination.” (Compressor 4)
    Posted by Harrison Sim on June 9, 2012 at 3:56 pm
    I keep getting the error message in the subject when I try to submit a job.
    Here’s a screen shot of my job:
    Not entirely sure what I’m doing wrong.
    -Harrison
    Brad Elliott replied 14 years, 3 months ago 2 Members · 1 Reply
  • Brad Elliott
    June 14, 2012 at 9:06 pm
    The second setting line needs a setting so that an icon appears on the far left side like the top setting. It appears you may have cleared the setting and/or destination on the lower setting.
    If you are not trying to create two versions of the the file then delete the second one. If you are trying to create two I would delete the second setting line and start over as Compressor doesn’t know what to do as is.
