Activity Forums Adobe After Effects Expressions One Expression to Push 2 objects apart
  • One Expression to Push 2 objects apart
    Posted by Brad Graber on March 24, 2020 at 3:47 pm
    Hi All,
    I want to have one expression, null, or slider that pushes two lines in opposite directions (x translates in opp directions) when I move the slider or null. I haven’t been able to find anything like this yet. I’m hopeful, though….
    BG
    http://www.smoobg.com
    Brad Graber replied 6 years, 6 months ago 2 Members · 4 Replies
  • Andrei Popa
    March 24, 2020 at 4:00 pm
    Not sure about the whole setup but I think this expressions in the position property could solve your problem:
    For the right one:
    distance = thisComp.layer("Null 1").effect("Slider Control")("Slider")/2;
    value+distance
    For the left one:
    value-distance
    Andrei
    My Envato portfolio.
  • Brad Graber
    March 24, 2020 at 4:24 pm
    Thanks for your response! See the screenshot below to reference what is happening. This also happened when I entered the expression exactly as you had it:
  • Andrei Popa
    March 24, 2020 at 5:01 pm
    I think you should first make the lines vertical and parent them to the NULL. Then rotate the null until they get in the position you want. Then add this to the x position property:
    The right one:
    var dist = thisComp.layer("Scale Null 2").effect("Slider Line Separator Control")("Slider");
    value+dist
    The left one:
    value-dist
    Andrei
  • Brad Graber
    March 24, 2020 at 7:26 pm
    Andrei Popa, this worked perfectly! Thanks so much! Maybe I’ll post a finished product or something…
