Activity Forums Adobe After Effects Expressions One expression that will work on one dimension or two?
  • One expression that will work on one dimension or two?
    Posted by Kevin Snyder on October 21, 2021 at 4:58 am
    I’m trying to come up with an expression that will work on properties that have one dimension or two dimensions. Here’s what I can up with, but it doesn’t work. I still get an error message. Maybe the catch(err) technique doesn’t work in this case?
    temp = thisComp.layer("Drive").effect("Drive")("Output 01");
    try{
    [temp, temp];
    }catch(err){
    temp;
    Kevin Snyder replied 4 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 21, 2021 at 6:46 am
    Try it this way:
    dim = value instanceof Array ? value.length : 1;
    dim > 1 ? [temp,temp] : temp
  • Kevin Snyder
    October 21, 2021 at 2:49 pm
    That works great. Thank you.
