Activity › Forums › Corporate Video › One Camera…or Two?
One Camera…or Two?
Posted by Jeffrey Gould on April 23, 2008 at 2:47 amHi, I just got a call from a past client who started her own Nurse Educator business and wanted a video of one of her classes, which are 2 days long. They use Powerpoint and Videos and at times dim the lights, there is also Q&A at the end. I plan on inserting the media in post production. I’ve shot hundreds of seminars with one camera, but they were mostly for “documenting” the event, this is to represent someone’s business.
So my question is: would I benefit from two cameras? I’m thinking a 2nd camera would be mostly for “insurance”, as I plan to keep the main camera on the teacher and follow the action. 2nd camera could be a wide shot of the room. I only have one camera, so I’d have to rent one…otherwise I’d just do it. Any thoughts on this? She wants a proposal ASAP.
Jeffrey S. Gould
Action Media ProductionsPat Ford replied 18 years, 4 months ago 8 Members · 25 Replies -
Mark Suszko
April 23, 2008 at 3:07 pmWhile there are techniques to make the one camera look like two or more, and we can cover that in another discussion, a job like this can benefit from two cameras. You get two more channels of backup audio, for one thing. Don’t neglect getting absolutely perfect audio for these things, it is even more vital than a good picture! You get continuity and a cover shot while you change tapes and batteries on each camera. You get audience cut-aways and reactions, and much more dynamic shot control of the speaker: you can punctuate her dialog by cutting to closeups, for example. You can avoid a lot of tromboning in and out for zooms, or having to cover that with slide closeups, if you have the second camera to go to. You can get better audience participation shots if there is Q&A.
You can adjust iris independently to get the best picture of the room and the best picture of the powerpoint screen.
That last may not be a big issue if you are adding the powerpoints back in during post from a CD copy, but still, being able to read or see the screen properly in a camera shot helps orient you to which slide you are going to see whan that slide comes up full. Subtle but effective.
If you can afford to add in the cost of the rental, and bill her, I’d go for it, as it will add a lot more professional look. If she say no, come back here and we can talk more about how to pull it off best as you can with just the one camera. I do this a lot.
Jeffrey Gould
April 23, 2008 at 3:48 pmThank you Mark, I agree 100% with all you said. Yes, I hate the zoom in, zoom out look…I like to cut it like a live TV show: cut to camera 2, camera one goes in for CU, then cut to that camera and have camera 2 pick up another shot. I don’t think I will have the luxury of saying “can we do that again from another angle”.
I would have to use wireless mics so they are free to move around. Not sure if a boom hanging from above would help as they are very dynamic and move a lot.
Speaking of Power Point, are there any new ways of importing a PP into Premiere? I used to convert each slide into a BMP, but it takes a quality hit. Would something like Camtasia work? Now I need to look around to rent the same or similar camera that I own: a Sony DVCAM 450WSL. I’m thinking 4:3 would be the way to go, since it will used in a classroom setting and not sure they will have a Plasma or LCD screen. Thanks again.
Jeffrey S. Gould
Action Media Productions -
Mark Suszko
April 23, 2008 at 4:20 pmRegarding PPT, you have several options. Dedicate a camera to shooting it off the screen, take the disk with the presentation on it and export the slides as jpegs instead of bitmaps, use a free download of Microsoft producer to make PPT export as an AVI file, use Camtasia or similar screen grabber, or buy or rent a scan converter and hook it to the computer vga port between the port and the projector or monitor.
With the scan converter, you could run that into a deck with an audio tap from your camera, and you get an iso track of just the slide show in perfect synch with the live presentation, so you can edit back and froth with it like it was another camera in post. The scan converter and camtasia will also grab any movements she makes with the mouse pointer, and any animated builds or transition effects the presentation has. Exporting stills does not, so if the transitions or builds are important to the client, you’d have to re-create them in the NLE application. Camtasia has a lot of satisfied fans, but it may not be for everyone. I’m not sure I would want to try to load and run it live during the client’s presentation, for example. It may use up too many processor resources, and hard drive space to store the massive video files it creates. Not great on some laptops.
You get what you pay for with scan converters. I own a 99-dollar one that works okay for the most basic powerpoint and screen grabs, but for serious work I would not bother with a unit under a thousand bucks. We use a Scan-Do Pro here that cost six gees brand new, it is awesome, but other brands in that price range are good too. Don’t panic, you can often rent one of those expensive ones for a day for maybe fifty to a hundred bucks, depending where you live.
Gary Chvatal
April 24, 2008 at 3:33 amTry to talk her into doing the course without the audince just for the camera. Shoot her. Then add the graphics and video later. That way you can shoot her properly with correct lighting. You could even bring in an audience for the Q&A if need be.
Jeffrey Gould
April 24, 2008 at 3:51 amGary/Mark, I asked about that, so that we could have a controlled environment and she said the instructors “work” better when they have an audience to play off of. I just wrote her and asked about the power points and wrote a company about renting a Scan Converter. I’m thinking the 2nd camera should be at 3 or 9 O’Clock to capture the teacher and students and I would be at 6 in the back of the room.
Then there is the whole legality issue, with filming nursing students in the class. Not sure how to handle the Q of the Q&A soundwise. It might be awkward passing a mic around, then again they do it on TV. In the past i have setup a mic on a stand and the people who wanted to ask questions would come up to the mic. Thanks for the replies.
Jeffrey S. Gould
Mark Suszko
April 24, 2008 at 4:09 amLecture attendees are very used to filling out sign-in sheets. Just add another sheet that’s a release form. Or put a sign on the door saying by entering you agree to be taped, and have the presenter repeat that information before she begins. If there are people that want to attend but not be on camera, you can put them in one designated corner that doesn’t get shot.
One of those strategies should work, I should think.
As to audio, you could have an assistant with a hand-held directional shotgun point it at people that speak, from one diagonal corner of the room. Works in a room of fifty people or less, needs fast hands on the mixer to ride the gain or you get too much noise along with the speakers. A field of PZM mics mounted on low ceilings could cover a pretty wide area unobtrusively, but also introduce noise.
I often use the planted hardwired mic stand for questions in a situation like this, but you need to plant enough of them to make it easy to get up and go to one, or people quit trying, then they try to shout from their chairs and that doesn’t work well at all.. you must stop everything and insist they go to a mic, make a pest of yourself about it… Plus, the speaker at the front of the room MUST enforce the rules by not responding to people unless they go to the mic. A side benefit of the mic stand approach is you can light just that spot and leave more of the room relatively dark. Good if you’re economizing on lighting, and makes the rest of the people there feel less singled-out…
I have also seen assistants run around with a wireless handheld to people that stand up. They can also be used to sort of pre-screen the questions in a whisper and decide on the fly if it is an appropriate time to ask that Question, or if it is a rehash of something already covered, or to be covered later in the show. Good for keeping things moving on schedule.
Clyde Villegas
April 25, 2008 at 12:06 amHi Mark. I’ve always been in situations where the client can’t afford a 2 camera setup so I’ve shot them with just 1 camera. How do you do it and still make it look like a TV show that shows the talent from one angle to another while he’s talking? Thanks and God bless.
Mark Suszko
April 25, 2008 at 1:58 amI didn’t mean to write a whole article, but I like to get it right and complete. So get a fresh cup of something and settle in.
The big secret to a good single-cam lecture gig?
Advance preparation and a plan in your head. It’s always nice to be the editor as well as the shooter because the editor half of you won’t give the shooter half any peace until you get enough coverage. But if you know how you’re going to edit later, the shooter knows what shots he can ignore as well.
For a single-cam powerpoint-driven lecture, the first thing I try to do/know is: Can I get the actual slides on a disk, preferably ahead of time.
If they’ve been promised, but not delivered, I show up extra-early to the event, when the speaker is just arriving and setting up. I will plant the camera directly in front of the screen in the best possible place, with the iris set for best viewing of the slides, and have the speaker click thru them all, one second per slide. That’s all I need, I can freeze frame them and extend their duration in post in a couple ways. When I use my dvcpro model 700 camera, it has a video input and can be used as a recording deck with a simple menu switch, so I can bring a pocket sized 99 dollar scan converter and do grabs to tape direct from the laptop’s VGA port, if I need to. Again, pretape one-second grabs of each slide. Also, 1 gig USB memory sticks and a handful of blank CD ROMS are DIRT cheap and easy to bring along in the camera bag or a keychain for copying the slides off. Either copy the whole presentation or quickly open Powerpoint and export>all slides> jpegs to a folder you already have prepared in your USB memory stick.
Knowing I have the slides on disk or pre-captured before the event, I now don’t have to worry so much about exposing for the screen. I can position, light, and expose for the speaker and any audience participation needs first.
I like to position the camera about 45 degrees off center, to the opposite side of the screen, so I have the choices of a single tight shot on the speaker alone, a medium with the speaker and maybe half the slide behind one shoulder, (with enough visible to be able to tell which slide it is) a wide shot with full-body of speaker and screen.
Because I got there early, I spend every last possible second before the show starts getting cut-aways of people in the audience in singles, trios, and bunches. If I can get behind the speaker at the podium to grab an over-the-shoulder with them in foreground and some audience in background, that’s a great cover shot you can use any time because you can’t see the mouth moving. You need a solid six seconds, minimum, of any cover shot you take, preferably more, but at least six. Slam-zoom to get them, tape them, and get out again. Try a couple rack focuses of foreground audience to background audience, to be artsy. Audience cutaways are best caught early when they look the most fresh and alert, and before they can escape when the lights dim…
Show begins, and I’ve already been rolling for ten minutes or so worth of cutaways…
Now assume for a second that for some reason you can’t pre-tape the slides, can’t get there fast enough, spent all your time fixing an audio or lighting problem and its too late.. whatever….. or, you don’t think you can get them afterwards because the presenter is a jerk or they have to catch a plane, or you do, etc.
This is what I do.
Disengage the servo zoom and put zoom on manual.
(“Luke, you’ve switched off your targeting computer, what’s wrong???” “Nothing, I’m all right…“)
Pre-set your focus for the speaker, note the setting. Same for the screen. Shoot the first slide for a few seconds full frame. Snap-zoom out super-fast to slide and speaker. Hold that shot. Speaker hits next slide. Figure he’s going to go about a minute on it. Hold the new 2-shot and listen to him, listen for him to finish a sentence or paragraph leading into the slide. Wait for it…. now, GO! Snap-in to to a tight shot of the entire slide, hold steady and count off six seconds…and snap back out to either a tight single of the speaker, the 2- shot, or a wide shot. Back home, after you clean the womp-rat skins, you’ll freeze and extend that tight shot and pull it back on either side of the cut to cover and extend over as much of the shot as you need. You can then pick when and where you copy/paste>drop it in again if the speaker stays on the same slide a long time. You can even find time for a fast audience cut-away with this technique covering for you. When you get comfortable shooting this way, you can start thinking like a live director; always think ahead to what your next shot needs to be, and be ready to SNAP to it.
What I try very hard to do is establish a subconscious visual rhythm to the work. I really listen to the presenter. Not just the content, but the vocal inflections that hint at summation statements. As each new concept or “chapter” comes up, I get the full-frame title slide for it, a paragraph of intro in CU of the speaker, followed by a wider shot that retains the slide, so you the viewer can keep your place, and I the editor can find the right cutaway later. Then finish with more closeups of the speaker. Because I can grab and extend slides later, or use the copy from the disk, I want to mostly shoot the speaker, and only enough of the projector screen to keep me oriented later in post, where I have much more control.
So we build up the repeating beats like that until the slides are all done. If you fast-forward a tape of my shoot/edit, you can see the repeating pattern of shots and count the “chapters” going by, and find a particular chapter very quickly. I believe a viewer gets a feeling of continuity out of watching a show cut this way, as well.
Best of all, your finished product will look like a live-switched 2-or-3-cam show of all cuts, not the more amateurish tromboning, nausea-inducing zoom-in-zoom-out junk people expect.
Audio-wise, I consult the speaker ahead of time to see if they are an immoveable podium-clutcher or a walk-and-talk duck-shooting-gallery target. I then usually put a wireless lav on them anyway, as well as plant a boundary mic or dynamic omni stick mic on the podium, because I am a belt-and-suspenders kind of guy, and because Murphy finds a harder time of it the more backups you have going.
The boundary mic sits on a spare, cut-down rubber mouse pad, so as not to pick up thumps and creaks. I feed these two mics to a Shure 4-channel mixer, strapped or gaffer-taped to my tripod in easy reach with one hand. The mixer goes to channel one, I leave the camera’s shotgun wide open on channel two. I monitor the audio the whole time. Spare tape and a peanut-butter-flavored Power Bar is in my shirt pocket, a bottle of water in my coat pocket, the camera is on AC with a spare 3-hour brick at my feet. Bladder is empty, I’m wearing comfy shoes and we’re good to go for hours.
I dare you to stop me. 🙂
For times when there is no room on the podium for my table stand, I made a cute inexpensive gadget from two Radio Shack mic clamps attached end to end. This little fella will hold my wireless stick mic clamped to the camera grab handle while shooting ENG off the shoulder, but it can also piggy-back my mic to a gooseneck or other table stand or floor stand, or even the side of the podium where there is NO stand. Costs about $20 to make, if you buy the clamps at Shack… seen the same thing for double that, online.
My biggest wild card to deal with is usually the hotel house audio. The house PA in most places I’ve worked is abysmal; I’ve never had the luxury of working in posh hotels with real AV in-house help. It is typically a hardwired, hands-off, no-changes-allowed, padlocked setup, and nobody from the hotel can EVER be found to answer questions about it or modify it beyond turning the power on or off. It’s a toss-up if there is a feed to tap from it, usually not. If it does have a tap, you’ll find the output buzzes and hums like a swarm of killer bees, and whichever impedance you are using, damn if it’s not the other. What to do?
Be over-prepared, of course. And always be thinking of work-arounds.
Sometimes I’ll sacrifice the mixer and use it inline between the hotel PA mic and the wall, getting my tap that way. Sometimes I’ll use a y-adaptor with XLR’s. Sometimes I’ll gaffer tape the two stick mics together, theirs and mine, so wherever they go, I go. Sometimes I’ll use the lav that way, gaffing it to the stick mic from the hotel PA, hidden from camera shot, slightly less bulky. I have a box full of Radio Shack audio adaptors and plugs, gender-changing adaptors, and an adjustable in-line attenuating pad in an XLR shell, to bring line levels down to mic. One time we had to lav mic a speaker cabinet… it’s war, you sometimes just have to improvise. Whatever it takes to get good sound.
Particularly with these lectures, the sound is of primary importance, more than anything else. They’ll forgive bad shots if the audio is good, but nobody will watch it if the audio is bad. In my kit, on general principle, regardless of the job, I always have two omni/cardioid stick mics with stands, one or two lavs (one phantom, one self-powered), a nice PZM, and two Lectrosonics wireless sets. Plus several sets of Canare brand or Starquad XLR cable in lengths of ten, twenty and fifty feet…
If I can’t get one useable audio track with all that… …fire me.
…Or admit it can’t be got by mortal man.
All that junk and more goes into a large mechanic’s satchel that looks like it belongs to Felix the Cat. It’s my video “Bag of Holding”. Last time I weighed it, it was around 35 pounds, sometimes it’s more. After hauling it around all day I’m sore, but I’m never sorry.
Because I’m as prepared for anything as a one-man-band can be, and fortune favors the prepared.
“Oh, you wanted to RECORD that?”
Jeffrey Gould
April 25, 2008 at 3:37 amMark…you’re amazing. I hope you’re successful, because you deserve to be. I’m sure I’m not the only one who appreciates all the time and knowledge you give to “us” on the Cow. Thank you.
Jeffrey S. Gould
Mark Suszko
April 25, 2008 at 4:03 amNope, just prolific;-) If I’m so smart, why ain’t I rich?
People define success differently. I wish I could define it from a restored ’68 Mustang, overlooking my island getaway and the 22 foot sailboat tied up next to it. I’m only ever going to see that as a comp, when I get skilled at using Adobe Photoshop and After Effects:-P
It still amazes me I’ve been just making a day to day living at it and feeding and raising a family this long, doing something I’d be doing for free as a hobby, if I wasn’t getting paid. While I’m far from rich, I ain’t diggin’ ditches either. I make a difference in my own small way and some days that’s enough.
And don’t make me out as smarter than I am: I’m sure there are plenty of other guys and gals here that use the same knowledge and techniques, I didn’t pioneer anything new, I just took the time to write it down for you. You would have figured out something similar eventually on your own, I’m sure. I’m just passing on things other people have taught me or that I’ve picked up along the way by experience or observation of others. One way I pay those folks back for teaching me something is to pass it on to someone else, like yourself. That’s what I love about this site, we’re all here helping each other out and building the biggest do-it-yourself textbook ever. I learn much more here than I have taught anyone else. I’m the one that should thank all of YOU.
