Activity Forums Adobe After Effects On line edit via AE?
  • On line edit via AE?
    Posted by Simon Cawthorne on December 8, 2005 at 3:54 pm
    Hi
    I have a set -up that can capture and export to broadcast quality.
    As such, I wish to avoid going to an external studio to use Avid Symphony to On-Line – can the online be done within After Effects (or Final Cut pro), so i can export a file that is ready –
    I assume it is a case of making the colours broadcast legal, and ensuring the sound is also properly formatted and the levels set correctly.
    As an extension of this – are there any tutorial or books about setting up and doing an online edit for FCP or AE?
    with thanks for any advice
    doogal
    Simon Cawthorne replied 20 years, 9 months ago 3 Members · 3 Replies
  • Tim Kurkoski
    December 8, 2005 at 5:31 pm
    AE isn’t an editing program, it’s a motion graphics, effects, and compositing application. Although you can accomplish many of the same things as an editing app, you’ll probably get frustrated trying to accomplish them. AE will be good for color correction, certainly, but for what you’re looking at, stick to FCP.
  • Jim Kanter
    December 9, 2005 at 4:07 am
    You can edit in AE but it isn’t as easy as in FCP, Premiere, or Avid. You can slip and slide edit as well as trim clips, but you can’t ripple or roll edit. Also, each clip is on its own layer, making for VERY complex compositions.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Simon Cawthorne
    December 9, 2005 at 9:39 am
    Hi
    Thanks for this – I’ll head over to the FCP forum.
    doogal
