Activity › Forums › Panasonic Cameras › On Board HD Monitor for Varicam
  • On Board HD Monitor for Varicam
    Posted by Dusty Powers on May 19, 2005 at 3:45 pm
    I’m looking to purchase an on board hd monitor with waveform for my varicam. Any reviews when comparing the Astro and the Panasonic? Any suggestions would be helpful. Thanks
    dp
    Dusty Powers replied 21 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • John Sharaf
    May 19, 2005 at 3:50 pm
    Dusty,
    I have both an Astro (without waveform though) and Panasonic 8″ LCD and I highly prefer the Panasonic. It’s menu is fairly complicated but so are the Astro controls and the Panasonic has two HD-SDI inputs, which is helpful in lining up two-camera shoots. I understand there is currently a promotion in place whereby Panasonic is giving the monitor away with a new Varicam!
    JS
  • Dusty Powers
    May 19, 2005 at 3:57 pm
    Good morning John. Thanks for the suggestion on the Panasonic. I was leaning in that direction, but wanted to ask before I made the purchase. Since I’m not planning on buying another Varicam in the near future, any idea what the monitor may be selling for at this time without the camera?
    dp
    Dusty Powers Video, Inc.
    Coastal NC
    910-520-5240
  • John Sharaf
    May 19, 2005 at 5:13 pm
    Dusty,
    Panasonic LCD kit prices as follows (all list):
    BT-LH900 @ $4890
    Portabrace Case @ $199
    Power cord to AB tap @ $135
    HD Isreali Arm & Slide Shoe Mount @ $197
    Call Pete at Birns and Sawyer and mention my name for a good discount.
    John Sharaf
  • John Sharaf
    May 19, 2005 at 6:32 pm
    Rumor has it that panasonic has actually lowered the list price to $4200???
  • Bruce Schultz
    May 20, 2005 at 4:27 pm
    Dusty,
    I have that monitor also, be aware that it is actually a 4:3 screen, but that appears to work out when you use the waveform as it places it below and right of the camera image. No cropping or letterboxing occurs. Also, it has a LUT for gamma when you are in the low-con mush of 400% or 500% Dynamci – which works fairly well but nothing like Ecinema’s box.
    All in all, I am happy with the monitor and use it for SD as well as HD. BTW, my Z1U HDV component output works on it also.
    One last thing, you need to use the large Israeli arm for it, as it gets very unweildy with a battery onboard.
  • Dusty Powers
    May 23, 2005 at 3:16 am
    Thanks for your input John. Good to hear from you.
    dp
    Coastal NC
    910-520-5240
  • Dusty Powers
    May 23, 2005 at 3:19 am
    I appreciate your input Bruce. My sense is the Panasonic is the way to go.
    dp
    Coastal NC
    910-520-5240
  • Erich Roland
    May 24, 2005 at 12:26 pm
    I have both these monitors in the rental inventory. and use them also. Where the Astro is good for the director to view what your up to for composition, if you want to reference a monitor for lighting, or color the Astro fails miserably, and the Panasonic is darn good for a LCD (best I’ve ever seen). As for onboard, the Astro is lighter and smaller, a desent size for onboard, the Panasonic is heavier and larger, but it certainly can be done.
    The Panasonic has one major flaw, and that is the connector from the control unit (Panasonic seperated for some kooky reason) that is very suseptable to having issues, i.e. breakage. Even with that MAJOR design stumble, the Panasonic 8.4 is a shiner, and with the resent price reduction this is a solid winner!
    Erich Roland
    http://www.dc-camera.com
    Digital camera rentals, Washington DC
  • Dusty Powers
    May 24, 2005 at 9:54 pm
    I just purchased the Panasonic from the guys in NY and I’m very pleased with the picture quality. The Panasonic also had the best price. Thank all for your input.
    dp
    Coastal NC
    910-520-5240
