Activity › Forums › Adobe Premiere Pro › OMG! It’s telling you do not have enought system requirements
Posted by Robert William on July 3, 2010 at 9:31 pmWhat do i do? I want to install Adobe Premiere Pro CS5!
Brian Louis replied 16 years, 1 month ago 5 Members · 9 Replies -
Brian Louis
July 4, 2010 at 11:48 amSince you are not describing your system specs, you need to make sure you meet minimum requirements:
https://www.adobe.com/products/premiere/systemreqs/ -
Robert William
July 5, 2010 at 1:40 amThank you for your responses. Well how can i tell you what system information?
Brian Louis
July 5, 2010 at 11:27 amDoes your system meet the minimum requirements listed in the link I gave you? if you aren’t sure post what your system is, operating system, cpu, memory, video card, motherboard
Robert William
July 5, 2010 at 2:07 pmI found my system info when i entered BIOS.
System info
System S/N: MXD 52301P2
System Chipset type: Intel 82865GV ICH5 82801EB
BIOS version: 1.15
BIOS readers date: 0413105
MOC address: OOFFE33AP2D
CPU/Mmemory info:
CPU Type: Intel CT Pentium (4) 4 CPU 3.20 GHz
CPU Speed: 3200 MHz
FSB Speed: 800 MHz
Cache L1: 16KB
Cache L2: 1024KB
Ratio Status: Locked
DDR Frequency: 4000 MHz single channel mode
Memory DIIM1: 256 MB
Memory DIMM2: 512 MB
Memory DIIM3: 256 MB
Memory DII4: Not controlled
Available System Memory: 1016 MB
Legacy VGA memory: 8MB
this is some stuff i found on the computer
Free space: 25.0 GB
Used space: 49.4 GB0.99 GB of RAM
Microsoft Windows XP
Professional Version 2002
Service Pack 3, v.3244 -
Robert William
July 5, 2010 at 5:02 pmI clearly don’t have enought RAM or operating system but if i get windows 7 not the ram will adobe install? and also if i install windows 7, will i still have all files and settings i’ve saved on this counter. I also checked NVIDIA.com and i have latest drivers.
Jon Barrie
July 5, 2010 at 9:10 pmIf u look at the adobe minimum specs you’re system is too old.
https://www.adobe.com/products/premiere/systemreqs/You will need a core2duo CPU, new motherboard for the CPU, bare min 2gig ram, but 4gig is more likely to get u started (most recommend 12gig). Windows7 64-bit, Etc. You need a new system. Upgarding your current hardware is not an option.
– Jon Barrie
Jon Barrie
aJBprods
http://www.jonbarrie.net
http://www.suiteskills.com -
Brian Louis
July 6, 2010 at 1:17 am[robert william] “but if i get windows 7 not the ram will adobe install?”
You basically need a new computer, unless you have a good case and can install parts by yourself, as it looks you need to upgrade everything, so the best way to go would be to buy off the shelf, and keep in mind you maybe have to add things like extra harddrives for video data, etc.
