Activity Forums Adobe Premiere Pro OMG encore cs4 will give me a heart attack
  • OMG encore cs4 will give me a heart attack
    Posted by Gil Sabag on July 12, 2010 at 6:50 pm
    I’m trying to build a blu ray dvd from premiere using footage mpeg 2
    1044 by 1080i,after I solve all of my encore problems I started the build,someone told to use h.264 codeck,and it takes forever,I have an I7 pc and I see the cpu dosn’t work so hard,so why does it take it so long,the lenght of the project is 3.5 hours, and it’s a 2 cameras project and thers a lots of effects and a lots of music clips,is that the reason?if so what do I need to do so it would go faster,I’m trying to burn it on 50GB blu ray disk,shall I split the project?shall I use diffrent codeck?diffrent preset?help me please,I need to finish it by tomorow,and the way it goes I don’t see it happends,need your help,thanks Gil.
    Panos Ioannou replied 16 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • Vince Becquiot
    July 12, 2010 at 8:47 pm
    Hi Gil,
    First, I should ask about the 1044 x 1080. Unless this was a typo, your outcome with this odd resolution probably won’t be pretty. Can you tell us where the footage comes from.
    Yes, h.264 for BLURAY is what I would recommend as well, but 3.5 hours of footage is going to take a long time to render, no matter what hardware you are on.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Gil Sabag
    July 12, 2010 at 9:07 pm
    Yes it’s a typo,the footage resolution is 1440 by 1080,do u have any ideas how to cut my render time?
  • Vince Becquiot
    July 12, 2010 at 9:08 pm
    Other that unchecking Max quality, I’m afraid you’ll need to walk the dog a couple more times…
    Vince Becquiot
    Kaptis Studios
  • Brian Barkley
    July 12, 2010 at 9:31 pm
    Exactly how long is it taking? 3.5 hours of HD is a LOT of material. It is no small miracle that Encore can even handle it, but it can.
    You’ll have to be like Job and have patience.
  • Gil Sabag
    July 12, 2010 at 10:00 pm
    Well as it turns out it CAN’T,I’v split the project into 2 parts hopefully it wont crash,the biggest problem I think is the 3rd party effects that I’m using, it make the project so heavy to work for starters,I’m gonna install the matrox rtx 2 of mine tomorow that way I’ll have more realtime workflow and maby better transcodig time.I just hope it’s not the sd card I don’t remember what we bought for the studio,I hope it’s the hd or just matrox rtx.2,anyways thanks for the help.Gil.
  • Gil Sabag
    July 12, 2010 at 10:33 pm
    And vuala another problem it gives me this messege “Blue-ray object: (here is the name of the project) Export file not found,what do i do I’m going crazy with this softwear.encore cs 4 if u asking.
  • Gil Sabag
    July 13, 2010 at 11:21 am
    I don’t know what does it mean,does anybody? I sure can your expertise on the subject,I’v split the project into 3 parts so it will have easier transcoding,but it gives the messege anyways,please sombody.
  • Vince Becquiot
    July 13, 2010 at 3:12 pm
    Try this first.
    Create a new DVD project, then in your preferences, clean the media database.
    Vince Becquiot
    Kaptis Studios
  • Panos Ioannou
    August 19, 2010 at 3:09 pm
    We are having the exact same problem and have tried all the above and no luck. Any ideas anyone?
    CS4 Production premium suite
    Windows 7
    Blu-Ray project -encore
