Activity Forums Audio OMF Question. FCP –> Pro Tools
  • OMF Question. FCP –> Pro Tools
    Posted by Rocco Rocco on July 9, 2009 at 5:15 pm
    In Final Cut Pro you can un-enable a clip whereby it sits in the timeline but is switched off. When I export an OMF to Pro Tools, do my un-enabled audio clips translate into the OMF and become visible in Pro Tools? I did a test using Soundtrack Pro and the un-enabled tracks DO NOT come through. I was wondering if this is the same in Pro Tools?
    Thank you.
    John Fishback
    replied 17 years, 2 months ago
    2 Members · 1 Reply
  • John Fishback
    July 9, 2009 at 5:24 pm
    It’s the same. In FCP you can use this feature to export stems (dialogue, music, fx) instead of an entire mix.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
