Activity Forums Apple Final Cut Pro Legacy ** Oh Crap … Overwrote FCP project File.. Help!
  • ** Oh Crap … Overwrote FCP project File.. Help!
    Posted by Mark Pommett on April 14, 2009 at 10:05 pm
    Made a big mistake. Opened up clients project. Got the message saying FCP had to update the project to newer version. Accidently hit save and overwrote project file.
    Is their anyway to revert this or make it backwards compatible so director can open it? I believe they were on an earlier version of FCP6 since it was done in Pro Rez.
    I have a feeling I’m royally F*&^ed and will have to give them an updated copy of FCP.
    Jeremy Garchow replied 17 years, 4 months ago 4 Members · 5 Replies
  • Brad Bussé
    April 14, 2009 at 10:11 pm
    First, backup the client’s Autosave directory. Then locate the newest autosave file that exists before the project type was changed, and see where that gets you.
  • John Fishback
    April 14, 2009 at 10:37 pm
    You can try exporting a XML file which the earlier version of FCP should be able to open.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Jeremy Garchow
    April 14, 2009 at 10:58 pm
    [Mark Alexander] ” I believe they were on an earlier version of FCP6 since it was done in Pro Rez. “
    This doesn’t make sense to me
  • Mark Pommett
    April 15, 2009 at 1:20 am
    I’m on FCP 6.0.4 so they must’ve had saved the project file on a slightly earlier version since I see Pro Rez files. If I remember correctly. Pro Rez was released in FCP6 (FCS2).
    Maybe it won’t be a big deal for him to upgrade. I’ll let him know what happened. I’ll have to bite the bullet and be more careful next time.
    producer of wedding videos in las vegas
  • Jeremy Garchow
    April 15, 2009 at 2:35 am
    [Mark Alexander] “I’m on FCP 6.0.4 so they must’ve had saved the project file on a slightly earlier version since I see Pro Rez files. If I remember correctly. Pro Rez was released in FCP6 (FCS2). “
    Yep, it was. It means that they need to do a free upgrade, although the most current upgrade is 6.0.5.
    Jeremy
