Activity › Forums › Apple Final Cut Pro Legacy › Ofset Transitions
Ofset Transitions
Posted by Dan Browne on April 4, 2008 at 3:53 amHey all,
Is there any way of offsetting a transition?
Cheers,
DDan Browne
Hawkes Bay, New Zealand
Cloud South Films
http://www.cloudsouthfilms.co.nzDustin Parsons replied 18 years, 2 months ago 5 Members · 7 Replies -
Dan Browne
April 4, 2008 at 4:08 amThat just offsets the clip, it doesn’t change the transition.
Dan Browne
Cloud South Films
http://www.cloudsouthfilms.co.nz -
Thaxter Clavemarlton
April 4, 2008 at 4:38 amIf you slide the cut-point then transition will happen earlier or later than it originally occured.
Andy Shnikes
April 4, 2008 at 5:42 amtheres a better work around i think, if you want a simple cross dissolve, go into the motion of the selected clips, and place your next track ontop of the first one, and use opacity key points to more accurately dissolve your clips.
I find it a bit more time consuming, but way less stressful than trying to insert a preset timed cross disolve, then having to deal with the headaches of my clip shifting when i lengthen or shorten the transition.
adobe premire, (god forbid) has a very useful transition track between video tracks 1 and 2, and it does the basic same thing as the opacity overlap idea. Except you have way more control over your transitions because you are not placing them directly onto your footage. While i like final cut way better for darn near everything, i miss the old days of premiere when i have to do something as simple as a stinkinng cross dissolve. (The most common transition known to man, and its a pain in the behind to use in final cut, seems to me, cross dissolves are the heart of editing, and final cut cant get this simplistic feature right.)
I havent tried to deselect the snapping tool, perhaps that would make transitions a lot easier, in the mean time, ill continue to use the motion opacity roundabout for extreamly complex cross dissolves that are less than or more than a second in durration.
There is a way in the preferences menu to adjust the transition default time length but honestly, wouldnt it be quicker to use opacity? (Unless you have to use a page peal, then god help you)
Martin Baker
April 4, 2008 at 8:26 amNo you can’t do asymmetric transitions on FCP. You only get starting at/centred at/ending at options, so you would need to slide the edit point to adjust the timing of the transition.
Martin
Digital Heaven, London UK
Unique plug-ins and tools for Apple Pro Apps
Avid2FCP
For Avid editors learning FCP -
Dustin Parsons
July 7, 2008 at 4:14 pmDern, that certainly is inconvenient, especially if you don’t want to do more than a simple cross dissolve.
I demand asymmetrical transitions and pudding! …sorry, I’m hungry.
Mac Pro | Leopard 10.5.3
2.66GHz Dual-Core Intel Xeon | 4GB Ram
Final Cut Pro Studio 2 | Avid Media Composer -
Dustin Parsons
July 7, 2008 at 4:15 pmDern, that certainly is inconvenient, especially if you don’t want to do more than a simple cross dissolve.
