Activity Forums Adobe After Effects Expressions offsetting an animation for several layers
  • offsetting an animation for several layers
    Posted by Shahed Naderi on June 6, 2014 at 2:35 am
    lets say I have null which is animated , I want 10 or more null repeat the same exact animation but with a bit of delay. and I dont want to set key frames to them , I need to make changes if needed to just that reference null, and I need to control the delay with an slider control.
    how is this possible ?
    I linked the properties on each null to reference null and then tried to use value.AtTime , but it dont work , I think it because the layer dont have any keyframe and actual value
    is there any work around ?
    Shahed Naderi replied 12 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 6, 2014 at 2:50 am
    valueAtTime() should work fine, but you need to define a delay (possibly some multiple of the layer’s index). For example
    delay = .1*index;
    thisComp.layer(“reference null”).transform.position.valueAtTime(time-delay);
    Something like that.
    Dan
  • Shahed Naderi
    June 6, 2014 at 11:14 am
    that’s working just fine , I was using valueAtTime in another row,and I should’ve use dot.
