Activity Forums Adobe After Effects Expressions Offset using Angle controller
  • Offset using Angle controller
    Posted by Ken Latman on September 15, 2008 at 5:44 pm
    What is the correct way to write an expression that uses a angle controller to shift the offset effect?
    The pickwip method just gets me all jumbled up. I basically made a slot machine and I want my own graphics to spin through and control them with the angle control.
    I took a look at Aharon Rabinowitz’s Creating an Odometer tutorial, but it doesn’t quite apply to what I’m doing.
    Ken Latman replied 18 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 15, 2008 at 7:05 pm
    Try this:
    angle = effect(“Angle Control”)(“Angle”);
    value + [0, angle * height /360]
    Dan
  • Ken Latman
    September 16, 2008 at 1:41 pm
    Thanks again Dan! This definately set me down the right path. My expression works great!
    Can’t thank you enough.
