Activity Forums Adobe After Effects Expressions Offset timing of 3rd and 4th Keyframe via slider
  • Offset timing of 3rd and 4th Keyframe via slider
    Posted by James Ronan on January 22, 2018 at 1:58 pm
    Hi there
    What I would like to do is to control what time the 3rd and 4th keyframes (one second apart) begin via a slider.
    e.g. If the slider value is 4, then the 3rd keyframe will start at 4 seconds and the 4th keyframe is at 5 seconds.
    If the slider value is 10, then the 3rd keyframe will start at 10 seconds, and the 4th keyframe will be at 11 seconds.
    etc. etc.
    I want to keep all the easing I already have between the two if that is possible.
    So far I’ve been messsing around with:
    if (numKeys > 2){
    dur = (effect(Slider Control")("Slider"))
    t = time - dur
    valueAtTime(t)
    } else
    value
    This is sort of doing it but not quite…
    Any suggestions would be awesome!
    James
    James Ronan replied 8 years, 7 months ago 1 Member · 1 Reply
  • James Ronan
    January 22, 2018 at 3:08 pm
    SOLVED!
    After more searching I’ve found an old post with something that will work:
    Instead, this uses a slider to hold the values between 2nd and 3rd keyframes…
    holdTime = effect("Slider Control")("Slider");
    k1 = 2; // 1st hold keyframe
    k2 = 3; // 2nd hold keyframe
    p = transform.position;
    t1 = p.key(k1).time;
    t2 = t1 + holdTime;
    if (time < t1)
    t = time
    else if (time < t2)
    t = linear(time,t1,t2,t1,p.key(k2).time)
    else
    t = p.key(k2).time + (time - t2);
    valueAtTime(t)
    The old post for reference:
    https://forums.creativecow.net/thread/227/18402
