Activity Forums Adobe After Effects Offset on Multiple Photos
  • Offset on Multiple Photos
    Posted by Mike Schrengohst on November 30, 2005 at 10:15 pm
    I am doing some quick & dirty photo montages.
    I can import 30 -60 photos at a time.
    I start the comp at the length I need the photos.
    Then I can do a batch opacity fade out.
    Then I reset the comp for the length needed.
    Is there a way to bring in multiple elements
    with a time offset so that I do not have to
    move photo individually??
    Mike Schrengohst replied 20 years, 9 months ago 2 Members · 2 Replies
  • John Dickinson
    November 30, 2005 at 10:23 pm
    Not sure if I totally understand but have you considered using the keyframe assistant “Sequence Layers”. Add all of your layers to a comp, select them all and trim them to the desired length ( ALT + ] ) then right click on one of the layers (still selected) and choose KEYFRAME ASSISTANT > SEQUENCE LAYERS. There is also an option to cross fade in there too.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Mike Schrengohst
    November 30, 2005 at 10:46 pm
    That was it!! You have saved me days of work.
    I love this list!!
