Activity Forums Maxon Cinema 4D Offset object clones position using Shear and Mograph
  • Offset object clones position using Shear and Mograph
    Posted by Miguel De mendoza on September 3, 2018 at 12:15 pm
    Hi, I’m making a recreation of that building:
    The building must build itself, so for the windows I need tu use Mograph. I createad a basic box with Shear deformer and used a clone in objecto mode, aligning the clones to polygon center:
    As you can see on the second picture, the vertical alignment of the clones is like a brickwall. I need that the clones get aligned like in the real tower. Is there any way to do that? And if it is, is it posible to mask the outside edges of the clones to avoid this stair like edge and make it straight?
    Miguel De mendoza replied 8 years ago 4 Members · 5 Replies
  • Brian Jones
    September 3, 2018 at 4:01 pm
    I’d try a plane that’s as wide as the building side profile and then use the knife to cut the angle you need rather than sheer.
  • Adam Trachtenberg
    September 5, 2018 at 4:54 pm
    You could go into the Cloner’s transform tab and manually adjust the bank angle.
    Or if you’re animating the shear you can probably use expresso to drive the bank angle with the shear object’s angle parameter.
  • Miguel De mendoza
    September 10, 2018 at 4:40 pm
    Thans Adam. I tryed changing the banking, but the clones are alredy deformed by the shear so they are like diamonds and dont align well. What I have done is use Grid Array from Object surface and passed a sheared mesh to it
  • Emir Bojorquez
    September 10, 2018 at 9:20 pm
    I hope this could help you to start with:
    12704_examplebuildingmograph.c4d.zip
    Good Luck
    Imagination is the best tool…
  • Miguel De mendoza
    September 11, 2018 at 7:32 am
    It’s a very interesting way to do it, especially to integrate it with Xpresso and python, what is my final objective. Thanks Emir!
