Activity Forums Apple Final Cut Pro Legacy Offset in RS-422 operation
  • Offset in RS-422 operation
    Posted by Jean-christophe Boulay on January 23, 2009 at 5:19 pm
    Hi guys,
    We regularly capture DigiBeta tapes to FCP through an AJA IO using RS-422 to control the DVW-500 deck. We also dump picture back to tape using the same workflow. Most of the time, everything is smooth sailing, but once in a while, with no kind of regularity, an offset seems to insert itself in the 422 messages and all operations are offset by that value. The value is not consistent either, but is usually around 4 seconds, always negative. Closing FCP and reopening it solves the problem all the time.
    For captures, this is just a slight annoyance, but it could eventually cause a problem when editing to tape. Does anyone have an idea what could be causing this?
    Setup: G5 dual 2GHz (Model A1047), 2.5GB RAM, 2xWD7500AACS HDDs, OS 10.4.11, AJA IO w/latest drivers, FCP Studio 2, Sony DVW-500
    Jeremy Garchow replied 17 years, 7 months ago 3 Members · 3 Replies
