Activity › Forums › Storage & Archiving › Offloading Speeds on Mac Pro with mTape to LTO-6..
Tim Jones replied 11 years, 6 months ago 7 Members · 26 Replies
Simon Blackledge
February 19, 2015 at 8:51 pmSo if I attach a usb3 1tb drive to another port on newmacpro and copy 1TB from the 8050 to it the 8050 would in theory overheat?
Or is this just streaming to tape using Bru? Archiware has a sw buffer that fills then streams. Is Bru similar?
Wouldn’t say Areca are cheap compared to Highpoint.
Tim Jones
February 19, 2015 at 9:21 pmNope – that copy operation still uses the filesystem caching and scatter-gather that I discussed earlier. So that we can demonstrate that it’s not BRU, try this:
cd /Volumes/1st_Areca_Array
sudo tar -cvf - | (cd /Volumes/2nd_Areca_Array ; tar -xf -)
Give it 20 minutes or so and – Boom!Tim
Tim Jones
CTO – TOLIS Group, Inc.
https://www.tolisgroup.com
BRU … because it’s the RESTORE that matters! -
Simon Blackledge
February 19, 2015 at 9:33 pmCan I use a usb drive as 2nd volume using that command?
All one command?
Will it hose the areca or just need a restart?
Tim Jones
February 19, 2015 at 9:48 pmIt shouldn’t hose the Areca, but may as it can actually gray-screen the Mac.
Make sure that the secondary drive is fast enough to handle the output of the original array, otherwise, the read speed will be reduced enough to invalidate the test. I would recommend an SSD via TB or at least a 2 drive stripe USB-3 array.
Tim
Tim Jones
Simon Blackledge
February 23, 2015 at 12:05 pmAre MAXX DIGITAL aware of this ? I think their 8 bats are Areca also :-/
s
Tim Jones
February 23, 2015 at 4:54 pmNot sure – I’ll ping Devon.
Tim
Tim Jones
