Activity › Forums › Storage & Archiving › Offloading Speeds on Mac Pro with mTape to LTO-6..
Posted by Suny Behar on February 10, 2015 at 4:48 amHey Folks,
I have about 20TB of 4K DPX files (in separate folders). So each folder contains about 1 minute worth of 4K DPXs (about 55MBs each x 1 minute) so about 600GB.
I have had ZERO luck trying to archive these to LTO.
I have a 24TB ARECA RAID 5 Drive (thunderbolt), and an mTape (thunderbolt enclosure). Installed latest drivers, running 10.9.5 on a Cylinder Mac Pro…
First tried PreRollPost, going the LTFS route. Would set it to offload, and would wake up in the morning to either 1) a frozen Mac, (off we go with a restart) 2) a message that said I had only transferred half the media and had 40,000 errors in copy and in verification. When I click “Details” , got nothing…
Then downloaded BRU PE to try my luck there… and well.. not a ton better…
1) First attempt Froze mac after about 60GB…
then I re-installed Mac OS X, re-installed all drivers, re-installed BRU PE…
2) This time, offload has proceeded… but at a SNAILS pace…. it offloads for about 5 seconds… pauses for about 30… then offloads for another 5 and pauses for 30… I’m getting around 100GB per hour of archive… At this pace, I think I will die of old age before I am prompted to insert the next tape…
Any help would be appreciated 😉
Tim Jones replied 11 years, 7 months ago 7 Members · 26 Replies -
David Roth weiss
February 10, 2015 at 6:32 amDid you download the latest drivers from mTape? I believe there may be a special one compatible with BRU PE.
Have you called tech support at mTape or Tolis (BRU)?
David Roth Weiss
Director/Editor/Colorist
David Weiss ProductionsDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Suny Behar
February 10, 2015 at 6:43 amI did download the latest drivers from mTape. I could not find a special one, there is only one driver on mTape’s website…
I contacted tech support at BRU and so far was only told to make sure I have the latest drivers…
that’s getting pretty old 😉
David Roth weiss
February 10, 2015 at 6:45 amI understand your frustration. You should definitely call mLogic.
David Roth Weiss
Martin Greenwood
February 10, 2015 at 10:45 amAs you have tested with two different archive apps it could be a faulty drive, to help troubleshoot you could download our app YoYottaID LTFS.
When run it will check that you have all the correct frameworks for LTFS and driver for mTape.
If anything is needed it will download and update to the latest versions.https://yoyotta.com/help/demo.html
If you have the same problems, then please contact me and I can take a look at the Mac system log to troubleshoot.
Martin Greenwood
martin@yoyotta.com
CTO YoYotta -
Tim Jones
February 10, 2015 at 4:45 pmHi Suny,
Unfortunately, all that we can offer is to insure that you’ve downloaded their latest firmware and drivers. Unlike ATTO and HighPoint, the Areca team has been very strict with their work in resolving the tape I/O issues that we identified in their driver / firmware stack over 5 years ago. It wasn’t until they discovered that their drivers didn’t work for the mTape unit that they even tried to make any effort in resolving the issue.
I have contacted the mLogic team. In the mean time, our engineers are building a version of BRU PE that may provide a more detailed examination as to why the data flow is so slow. Check your support ticket for a download link later today.
Tim
Tim Jones
CTO – TOLIS Group, Inc.
https://www.tolisgroup.com
BRU … because it’s the RESTORE that matters! -
Tim Jones
February 10, 2015 at 6:09 pmOne additional bit of information that our lab team just shared with me – the Areca RAID cards are known to have heat problems when backups are running. Unlike normal disk I/O when you are writing data in bursts, the act of reading data from the device for backup is a continuous stream of data with very few breaks (especially with LTO-6). He have had our Mac Pro and Windows systems physically shut down because the Areca card overheats. When we shared this issue with Areca US support, their guidance was to open the case and aim a desk fan at the system.
While it is unfortunate and something that I don’t like to have to do, we now recommend to our customers to stay away from Areca RAID adapters for non-server installation as they are simply not stable in extreme I/O situations where you are not running them in a controlled server infrastructure environment (forced cooling, humidity control, etc.).
Tim
Tim Jones
Suny Behar
February 10, 2015 at 6:52 pmThanks for the info Tim!
In this case, the ARECA Raid controller card is in the free standing 8 Bay RAID Drive chassis (not inside the cylinder Mac Pro which does not accept PCIe cards obviously). Does this advice still apply? The RAID drive chassis is connected to the Mac Pro via Thunderbolt. Are they recommending that I remove the case from the RAID Drive chassis to expose the drives and card? Thanks for clarifying.
Suny Behar
February 10, 2015 at 7:15 pmHey Martin,
Thanks for the offer, that’s very kind of you.
I will download the demo and see what I get.
Cheers!
Suny
Tim Jones
February 11, 2015 at 4:15 pmSuny,
It could very well be their enclosure. Since you’re running with 8 drives, there’s a lot of heat generated – especially during a backup / archival operation where you’re not simply copying files. In our tests, we were able to burst write or burst read from an Areca-controlled array, but when we started continuous and contiguous reads from the controlled array, the HBA would overheat and the Mac wold either hang or fully gray-screen.
As contrived as this may sound, if you have a small desk fan, you might try placing it in front of the case (open the front door if there is one) and blow air across the drives to reduce the heat that they output. This may be enough to reduce the heat profile within the case and keep the Areca controller under critical temps. It’s what Areca’s tech rep suggested to us when we reported the issue and it did work when the fan was on medium or high speeds.
Tim
Tim Jones
Neil Sadwelkar
February 17, 2015 at 5:12 pmI haven’t used the Areca Thunderbolt RAID 8050 myself, (https://www.areca.com.tw/products/thunderbolt.htm) but have known other DITs use it as a on-location backup for camera data and it has been reported to work flawlessly even in ‘non-ideal thermal’ environments. And they’ve used the Areca along with StorageDNA so Areca to LTO is also a working combo.
What you could try is to disconnect the mLogic LTO drive, and instead connect any USB3 drive to the MacPro and, of course, the Areca 8050 to the Thunderbolt port of the MacPro.
Next, simply do a Finder copy of about 1.5 TB of data from the Areca to the USB3 drive.
This will sort of simulate an LTO backup. If the Areca successfully streams this large amount of data to the USB3 drive, then the Areca is fine and capable of reading large amounts of data.Next, you take this same 1.5 TB data now on the USB3 drive, and, with the Areca disconnected, copy it over to LTO tape in the mLogic drive. Using Bru-PE. If this too works, then there’s is some compatibility issue between the Areca and the mLogic.
If, on the other hand, this copy (Areca to USB3) doesn’t succeed, then the Areca might need to be replaced.
BTW how did this data get into the Areca in the first place. If it copied this huge amount of data successfully, then the unit seems to be working fine.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
