Activity Forums Apple Final Cut Pro Legacy Offlining in FCP
  • Offlining in FCP
    Posted by Chrome on August 15, 2007 at 4:00 pm
    Is there any books or other resources that cover offline in FCP specifically for onlining in Avid? I can’t find anything.
    TIA
    Cheers,
    Chrome
    Mac G5, Dual 2.5, 8Gb, Media G-Raid, 30″ Cinema, Decklink HD Pro, HD-Connect-LE
    Matt Devino replied 19 years, 1 month ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 15, 2007 at 4:11 pm
    Whatcha need is Automatic Duck….
    https://www.automaticduck.com
    Works great.
    Jerry
  • Matt Devino
    August 15, 2007 at 5:13 pm
    As long as you do you offline at the same timebase as your online you should be all set, i.e. if your finish is on HD at 23.98 do your offline at 23.98, and make sure if you’re editing from DVCAM or any other 29.97 format you remove your pulldown before you edit. Of course if your source was 29.97 stay at 29.97. Then once you’re done you can either go the EDL route or Automatic Duck (which is better), although neither are perfect. If it’s possible you may want to think about doing your online in Final Cut, it will save you a lot of time and money if you have a lot of effects in your Final Cut timeline.
