Activity › Forums › Apple Final Cut Pro Legacy › OfflineRT and Hi Res Pictures
  • OfflineRT and Hi Res Pictures
    Posted by Darren Hallihan on June 27, 2009 at 11:30 pm
    So I have a Hirez quicktime (apple pro res 422 (HQ) 1280×720) and a boat load of pictures(3072×1358). I imported them all into a project and then choose to recompress to offlineRT. Now the quicktime shrunk dramatically but the pics stayed the same size. If I cut like this, when I go to reconform to the online material will my moves on the pictures be OK?
    If I do moves in Motion will it translate later to the online?
    Or do I give up on the offline aspect of this and just cut in prores?
    Darren
    Shane Ross replied 17 years, 3 months ago 2 Members · 1 Reply
  • Shane Ross
    June 28, 2009 at 4:13 am
    If you do still moves in Offline RT, then the frame size will be wrong and you will have to redo all the moves when you online. If you do them in Motion, and export as Offline RT, when you online just export as ProRes and you will be fine.
    Shane
