Activity Forums Apple Final Cut Pro Legacy Offline to Online worry. HDV footage is already captured!
  • Offline to Online worry. HDV footage is already captured!
    Posted by Gnwanya on December 7, 2006 at 10:43 pm
    Hi guys,
    I initially captured HDV native footage to edit in FCP, but ran into problems…My machine just isnt fast enough. So using Media Manager, I created a low res offline version of my project including orignal HDV native clips I already have in my browser. I have started working on editing clips on the new low res sequence but felt i needed to get an answer to my query before i go any further.
    Once i have finished my edit, and decide to res up again, will FCP Media manager recognise the clips i have captured already, or will i be asked to recapture the HDV footage again? Im only asking this as I can only find information about recapturing hi res footage after a lo res edit is done. And nothing about using hi res clips that have already been captured.
    Any help is appreciated
    Gus
    Jeremy Garchow replied 19 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Zak Mussig
    December 7, 2006 at 10:55 pm
    I’d imagine you could just take all of the clips in your timeline offline, change your sequence setting and just reconnect to the already captured HDV versions of your media. Can anyone think of problems with that?
    Zak
  • Gnwanya
    December 7, 2006 at 11:27 pm
    Hi Zak
    Thanks for the response, Im hoping that once the edited sequence is done. I can just can go back through media manager to res up and it will relink or ask me to relink with the orignal files. I havent used media manager before, so im not aware of any problems i may come across. Nonethless im crossing fingers.
    Thanks again.
    Gus
  • Brian Lindstrom
    December 8, 2006 at 12:19 am
  • Gnwanya
    December 8, 2006 at 12:57 am
    Hi Brian
    Thanks very much, I beleive this discusses the scenario of having to recapture the footage. But its not recapturing HDV footage thats my problem as all my HDV footage is still on my external harddrive. My apologies if i am confusing things. I’ll start from the top.
    I already have HDV footage logged and captured natively, and i actually set about editing in a HDV sequence. But when i started to stack layers of footage on top of one another, i was unable to go beyond v3 without having to render every change. I after a few queries, i was informed i didnt have a fast enough system.
    So I seleceted everything in my browser window, (HDV footage, sequences) and went into media manager to compress the files into a smaller project. I opened that new project, and started re-editing only to realise i dont know how i can res back up to my HDV sequence once im done with the low res sequence.
    I had been mindlessly editing away without actually working out how to resolve my dilemma, and so this is where im at now. I want to now if i can swap out my low res sequence and footages with my hdv sequnce and footages, once i have finished editing.
    Again i hope this is clearer. Any advice is appreciated.
    Cheers
    Gus
  • Gnwanya
    Hi Brian
    Cheers
    Gus
  • Gnwanya
    December 8, 2006 at 12:59 am
    Hi Brian
    Cheers
    Gus
  • Gnwanya
    December 8, 2006 at 1:04 am
    Apologies!
  • Jeremy Garchow
    December 8, 2006 at 2:21 am
    Cut your low rez sequence, use media manager to create an offline sequence and set it for HDV. When that project opens up, reconnect all the media to your original HD media. The MM is a little misleading as when it says ‘create offline’ what you are really doing is taking the current media you have offline and then telling FPCP to make a sequence where all the clips are offline, but are in the newly chosen format.
    Confusing at first but makes sense later.
    Jeremy
