Activity Forums Apple Final Cut Pro Legacy Offline RT HD General Error when rendering/exporting
  • Offline RT HD General Error when rendering/exporting
    Posted by Dank_elly on May 31, 2007 at 8:18 pm
    I’m working on a large show with over 2000 reels of media that have all been loaded in photo jpg at 35%, the resolution is 384×216 and this is the codec setup that fcp puts out as Offline RT HD. There is a constant render issue, I get the general error message 9 out of 10 times when I go to render. There isn’t a general error number just the plain general error. Once in a while it will work after trying again and again, but most often not. Sometimes there isn’t a filter or any other clips on, and they still won’t render. If I create a sequence on one machine and export and render it from the same one, it will work, but I can only have one sequence open at a time. Anyone else experienced this with the offline rt hd codec?
    Dank_elly replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
