Activity › Forums › Apple Final Cut Pro Legacy › Offline editing with Apple ProRes media
Posted by Tony Ostrovsky on October 25, 2009 at 10:58 amHello,
I have Apple ProRes media and I would like to edit it in lower quality (offline?) and then substitute clips in the sequence with the original quality media.
Are there any tutorials on how to do that? Apple site is quite vague https://documentation.apple.com/en/finalcutpro/professionalformatsandworkflows/index.html#chapter=10%26section=5
Where to look for an answer?
Thank you!
Tony Ostrovsky replied 16 years, 10 months ago 5 Members · 10 Replies -
Walter Biscardi
October 25, 2009 at 12:47 pmQuite honestly Apple’s ProRes is pretty small media files. Most of us simply do the cut once using ProRes all the way through the editing process. Much easier to do this.
I you really want to work in a lower rez format, you can use Media Manager to Recompress all the files to something like DV.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Tony Ostrovsky
October 25, 2009 at 1:20 pmThe problem is, that files are Apple ProRes 422 (Proxy), 1920 × 1080. In Uni we have IMacs and FCP doesn’t even try to play them in real time (even though RT is set to unlimited). I’ve managed to edit DVCPROHD 720p online on a low-end MacBook white before – no problem.
I know how to convert files, but how do I change them to high-res ones after the editing is finished, without affecting the sequence (fades, etc. ) ?
Is there an option that will force FCP to play work with ProRes online, without giving me that Unrendered screen?
Thank you!
Walter Biscardi
October 25, 2009 at 1:28 pm[Tony Ostrovsky] “The problem is, that files are Apple ProRes 422 (Proxy), 1920 × 1080. In Uni we have IMacs and FCP doesn’t even try to play them in real time (even though RT is set to unlimited). I’ve managed to edit DVCPROHD 720p online on a low-end MacBook white before – no problem. “
That’s a problem with your media array, not the iMac. We’re cutting a documentary right now in ProRes using a 2 year old iMac with over 200 hours of 720p ProRes. We’ve also cut 1080i ProRes on there with no problems. We’re running a Final Share SAN connected to that machine.
Tony Ostrovsky
October 25, 2009 at 1:44 pm[Walter Biscardi] “That’s a problem with your media array, not the iMac. We’re cutting a documentary right now in ProRes using a 2 year old iMac with over 200 hours of 720p ProRes. We’ve also cut 1080i ProRes on there with no problems. We’re running a Final Share SAN connected to that machine.”
OK, thank you. Could you, please explain what ‘a problem with my media array is’? I’ve googled ‘media array problem’ and found one of your earlier posts, but you have not described how to check if my media array is properly set up.
Thanks again!
Anton -
Steve Eisen
October 25, 2009 at 2:28 pmYou need to edit using an external hard drive, preferably a raid. Check out Caldigit, G-Tech or Other World Computing for storage options.
Are you using your system drive as your scratch disk? That is not recommended.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Tony Ostrovsky
October 25, 2009 at 2:34 pmLaCie Rugged 500 GB 5400rpm via Firewire 800. 7200 should be better, of course, but I think 5400 is enough.
What other settings should I check?
John Fishback
October 25, 2009 at 2:38 pmHere’s a chart which shows you the sustained data rate needed from your array to successfully play various codecs.
And here’s an app from AJA that will measure the data rate of whatever drive you point it at. System Test.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Tony Ostrovsky
October 25, 2009 at 2:45 pmWow! Thanks for the information! I’m learning new things every day! 🙂
Zane Barker
October 25, 2009 at 3:59 pmWhat type of hard drives are you currently keeping your media on and how are they conected to the computer.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity!
