Activity › Forums › Adobe Premiere Pro › Offline clips all scattered and not in the right place after moving files from iMac to HD.
  • Offline clips all scattered and not in the right place after moving files from iMac to HD.
    Posted by Christopher Evans on January 20, 2014 at 6:37 pm
    Hey guys,
    Basically I did a project and all the files were on my desktop in a folder. I then copied that folder and moved it to another hard drive. Of course you would think to simply reconnect the offline media, but after I search for some clips and render, my timeline layout is all wack…clips are in places they shouldn’t be. It’s bizarre.
    The layout is the same, just some clips are different than before.
    Does this even make sense?
    Please help.
    Christopher Evans replied 12 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    January 20, 2014 at 8:43 pm
    Hi Christopher,
    Which version are you running? Did you apply any Premiere Pro updates recently?
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Christopher Evans
    January 20, 2014 at 9:06 pm
    Hey Kevin,
    I am using Adobe Premiere Pro CC and have not done any crazy updates yet.
    After I moved my files from my iMac to my external HD, things just got wacky on the timeline and I have no idea why.
  • Christopher Evans
    January 20, 2014 at 9:11 pm
    7.0.0 to be exact.
  • Morten
    January 20, 2014 at 9:53 pm
    Try a reconnect one more time. Mark the clips in the sequence, right click, and choose OFFLINE – then repeat and choose LINK. Point to the new location of the first clip. All the rest should reconnect automatically.
    One reason may be that you have clips with the exact same file name. This will confuse Premiere. You will have to locate those clips (right click and choose to Show File in Finder) and rename one of them to a unique name. When you relink these you will have to uncheck the same name option.
    – No Parking Production –
    Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8…. and FCPX on trial
  • Pat Horridge
    January 21, 2014 at 3:51 pm
    Yes don’t forget with some tapeless media the only identifying factors are filename and location. Move the location and you only have filename as a match. If you have sub folders with files of the same name in each then you will have problems.
    It’s not uncommon for some Post houses to use batch renaming tols to rename all the source files prior to starting the edit to ensure all sources are unique. Not an issue with P2 and xcdam etc as they have UMIDs.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Kevin Monahan
    January 21, 2014 at 4:05 pm
    Christopher,
    There was a bug in 7.0 regarding certain kinds of media. I suggest you update to 7.0.1, 7.1, or 7.2.1. Here are the updates:
    https://www.adobe.com/support/downloads/product.jsp?product=98&platform=Macintosh
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Christopher Evans
    January 21, 2014 at 5:02 pm
    Hey Kevin thanks again,
    Now I am unable to update my software for some reason…and ways around this?
