Activity › Forums › AJA Video Systems › offline capture of HD24p from JH3 deck into FCP
  • offline capture of HD24p from JH3 deck into FCP
    Posted by Busterfcp on August 22, 2005 at 10:28 pm
    I am wondering how to go about doing an offline capture of footage that was shot on an HD Cam at 24p from a JH3 deck. Can I use the firewire option? Will I be able to view it on an external monitor? What settings do I need to use on the deck and in FCP?
    Any guidance would be appreciated.
    Gary Adcock replied 21 years ago 4 Members · 12 Replies
  • 12 Replies
  • Walter Biscardi
    August 23, 2005 at 12:32 pm
    Simply connect via HD-SDI to the Kona 2 and choose what format you want to digitize to. The Kona does downconverts so you can set it to capture HD to DV or DV50 or DVCPro HD, etc…..
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Berenger Capmany
    August 31, 2005 at 9:35 am
    Hello There…
    I have a problem ,. I cannot digitize form HD-SDI to DVCPRO HD codec… the FCP app crashes out…
    works perfect capturing to DVCPRO, DVCPRO 50 or Uncompressed.. (I’m digitising from 1080i50)
    while I’m finding a solution to this problem.. I would like to advance in my project doing a offline…
    Can I digitise to an offline RT codec?
    will maintain the 16:9 and size ratio?
    or
    Can I do the offline with a DV codec (or DVCPRO50)?
    again, what will happen with the sizes/aspect when finally I will do the online at DVCPRO HD 50?
    thanks and Cheers!
  • Gary Adcock
    August 31, 2005 at 2:47 pm
    How can we help without any info on your config?
    Ram, Machine, system version, drivers, cards etc?
    if it cannot capture to DVCPROHD has it ever been able to?
    WHAT FORMAT?
    gary adcock
    Studio37
    HD and Film Consultation
  • Berenger Capmany
    August 31, 2005 at 10:40 pm
    Hello and thanks for the response I’m a little bit desesperated because i’m running short of time..
    the system is brand new….
    all the stuff is flaged at 25fps
    I can digitize via firewire 720p60 at 60fs
    I can digitize via kona2 720p60 and 25pfps
    setting the 1200 deck to 1080i50 HD-SDI out
    I can digitize via HD-SDI (kona2) from 1080i50 to ANY codec but dvcprohd50
    here is the config and the crashlog if it helps or gives any ligth…
    panic(cpu 1 caller 0x00798AF4): DART entry exception: HyperTransport write logical page 0x04800
    Latest stack backtrace for cpu 1:
    Backtrace:
    0x00095544 0x00095A5C 0x0002683C 0x00798AF4 0x006B8D70 0x006B8DA8 0x00668048 0x002CD5AC
    0x002CC474 0x000A9694
    Kernel loadable modules in backtrace (with dependencies):
    com.apple.driver.AppleGPIO(1.1.8)@0x6b6000
    dependency: com.apple.driver.IOPlatformFunction(1.7.0b1)@0x4e0000
    com.apple.driver.MacIOGPIO(1.1.8)@0x666000
    com.apple.driver.AppleMacRISC4PE(1.6.2d0)@0x792000
    dependency: com.apple.iokit.IOPCIFamily(1.6)@0x472000
    Proceeding back via exception chain:
    Exception state (sv=0x00DB9280)
    PC=0x00000000; MSR=0x0000D030; DAR=0x00000000; DSISR=0x00000000; LR=0x00000000; R1=0x00000000; XCP=0x00000000 (Unknown)
    Kernel version:
    Darwin Kernel Version 8.2.0: Fri Jun 24 17:46:54 PDT 2005; root:xnu-792.2.4.obj~3/RELEASE_PPCModel: PowerMac7,3, BootROM 5.2.4f1, 2 processors, PowerPC G5 (3.1), 2.7 GHz, 4.5 GB
    Graphics: ATI Radeon 9650, ATY,RV351, AGP, 256 MB
    Memory Module: DIMM0/J11, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM1/J12, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM2/J13, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM3/J14, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM4/J41, 256 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM5/J42, 256 MB, DDR SDRAM, PC3200U-30330
    Network Service: Ethernet incorporada, Ethernet, en0
    PCI Card: LSI,929X, scsi-2, SLOT-2
    PCI Card: pcif1d0,c0ff, sppci_video, SLOT-4
    Serial ATA Device: Maxtor 6B250S0, 233.76 GB
    Parallel ATA Device: PIONEER DVD-RW DVR-109,
    Fibre Channel Device: SCSI Target Device @ 0,
    USB Device: Hub, , Up to 480 Mb/sec, 500 mA
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: Macally Optical iceMouse, Macally Peripherals, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    USB Device: Apple Cinema HD Display, , Up to 1.5 Mb/sec, 100 mA
    FireWire Device: unknown_device, unknown_value, Unknown
    FireWire Device: AJ-YAD120AG, Panasonic, Up to 400 Mb/sec
    thanks again!
  • Gary Adcock
    September 1, 2005 at 12:08 am
    rostolls
    What easy setup are you using in FCP?
    what Kona driver version ( kona control panel > info tab)
    Which OS version? ( apple menu > about this mac)
    the crash log is only helpful with a couple of answers –
    note there is not a reference to anything but apple.
    gary adcock
    Studio37
  • Gary Adcock
    September 1, 2005 at 12:17 am
    [rostolls] “setting the 1200 deck to 1080i50 HD-SDI out
    I can digitize via HD-SDI (kona2) from 1080i50 to ANY codec but dvcprohd50”
    This is a down-convert. DV50 is SD only.
    there is no DVCPROHD50
    in HD the frame rate is 25 frame Not 50 fields
    if you are trying to work in SD you need to set the downconverter in the K2 control panel to get an SD signal
    everything in your note is HD not SD- but the compression you are referring to is SD only
    gary adcock
    Studio37
  • Berenger Capmany
    September 1, 2005 at 8:17 am
    Sorry sorry sorry
    it was a mistach while I was writing…
    and also my english, it’s very poor! (I’m speak Catalan so we construct sentences backwards!)
    sorry I meant capture to DVCPROHD (100) …
    anyway downconvert to any other codec works.
    I have received response from the AJA tech support and it’s a driver problem
    It will be solved in the next driver release (1.1.4) together with analog audio delay
    thank U anyway!
  • Gary Adcock
    September 1, 2005 at 11:36 am
    [rostolls] “it was a mistach while I was writing…
    and also my english, it’s very poor! (I’m speak Catalan so we construct sentences backwards!)”
    Not a problem, even some of us on this side of the pond cannot construct
    proper sentences, ( I for one stumble often on this)
    Glad we could help.
    gary adcock
    Studio37
  • Berenger Capmany
    September 1, 2005 at 10:09 pm
    yes!
    with the 1.1.4 beta drivers works perfectly…
    if fact if you read the release notes of the 1.1.4 driver “now capture to DVCPROHD 1080i50 is supported”
    so simply what I was trying was not supported by the driver….
    Greetings from the Mediterraean Sea!
  • Gary Adcock
    September 1, 2005 at 10:41 pm
    [rostolls] “Greetings from the Mediterraean Sea!”
    We are glad it is working!
    If your going to IBC stop by and introduce yourself at the AJA booth.
    gary adcock
    Studio37
