Activity Forums AJA Video Systems off topic – SATA host card for MAC Laptop
  • off topic – SATA host card for MAC Laptop
    Posted by Bob Zelin on June 25, 2005 at 7:47 pm
    is anyone aware of a PCMCIA SATA host controller card that can work in a MAC Laptop. I have recently used the Serious Magic DV Rack to record DV25 material for FCP, and I see no reason not to bring a full (semi portable) FCP system on a laptop in the field to record onto SATA drives at much higher resolution than DV25. I know that I could use FW800, but I was wondering if anyone was aware of a SATA controller for a LAPTOP (PCMCIA).
    The usual Firmtek, Sonnet, Highpoint, etc. appear to not make one. I can’t tell if the SATA PCMCIA cards that are out there on the web are MAC compatible.
    Thanks –
    Bob Zelin
    Jeremy Garchow replied 21 years, 3 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    June 25, 2005 at 8:15 pm
    https://www.usb-ware.com/siig-serial-ata-cardbus-dual.htm Don’t know if it will work with a Mac, but here’s a start anyway…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bob Zelin
    June 26, 2005 at 2:53 pm
    Thanks Jerry, but as you can see on the last line of “requirements”, it states the PC requirements with the different versions of Microsoft OS that it works with. I would hate to start randomly ordering $79 SATA PCMCIA cards, only to have to send them all back. It would be nice to find one that simply even suggested “Mac compatible”.
    Bob Zelin
  • Erik Hansen
    June 27, 2005 at 12:53 am
    Bob,
    This one is listed as Linux compatible – <.” target=”_blank”>https://www.usbfirewire.com/Parts/rr-ser-cardbus.html>. Might be a good start, plus it’s only $33.
    Best,
    – Erik
  • Jeremy Garchow
    June 27, 2005 at 3:25 am
    https://www.wiebetech.com/products/satadock.php
    It’s not cheap, or very elegant, but it will do what you need it to do
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
