Activity Forums Blackmagic Design off-line codecs
  • off-line codecs
    Posted by Grant Keiner on February 19, 2008 at 10:08 pm
    Hi All,
    I am posting this here as well as in the Final Cut forum. Basically I need to off-line a bunch of shows shot in HD 1920×1080 23.976fps. I will ingest HDCAM at some compressed rate then online each hour long show using prores HQ.
    Does anyone have suggestions for the off-line edit. I am considering DVCPROHD. photo jpeg. and XDCAM. Has anyone used XDCAM to “offline” in final cut? is this possible? I will ingest using a decklink HD Extreme.
    Does anyone have any other ideas?
    Margus Voll replied 18 years, 7 months ago 2 Members · 1 Reply
  • Margus Voll
    February 23, 2008 at 10:51 am
    Hi.
    I’d use Prorez all the way.
    It takes about 80 gigs an hour roughly if i do not mistake.
    So on TB you would have 10 hours or a bit bore roughly.
    You will have all a your material online so to say and
    no recapture. Drives and arrays are so low cost now days that i see no point for recapturing.
    Margus
    https://iconstudios.eu
